Flat Tire WTF!!!
Old Jun 17, 2002 | 07:11 PM
Turbo Powa's Avatar
Default Flat Tire WTF!!!
I was a my girls house the other day and when I left I had a flat tire. There were no repair shops around that area so I used a bottle of fix a flat and drove to the nearest air pump. Filled the tire up and drove it home. The next day I checked the tire pressure and it was down to 10psi. I drove it to the nearest gas station at my house and filled it up to go to the repair shop. My question is..... If you get your tire fixed is it still ok to drive at high speeds? I just bought these tires a month ago and I sure as hell dont want to buy new ones. Any suggestions?
Old Jun 17, 2002 | 07:23 PM
LoudLude's Avatar
Default Re: Flat Tire WTF!!! (Civic LX 29)
A local tire shop should be able to patch your tire for about $5. Then put that one on the rear of the car. Then order a new tire. The patch should only be used to get you by, no racing on it!
Old Jun 18, 2002 | 07:10 AM
Turbo Powa's Avatar
Default Re: Flat Tire WTF!!! (LoudLude)
Anyone else got any suggestions?
Old Jun 18, 2002 | 07:27 AM
BROOD's Avatar
Suggestions from a prior employee at Discount Tire Co.
1. You need to get the fix-a-flat out of your tires. It throws off the balance as well as eats the rubber from the instide out.
2. Take your tire to a place that repairs flats with a patch from the inside of the tire. No Tee handle plugs!!!! Expect separated belts if they use the layzie methods. Internal patches are the only way to go. I suggest Discount Tire because I'm familar with the ways they repair (internal patch) and it is free. Don't pay unless you have to.
3. Very important.......Tell the guy working on the tire (not only the guy at the counter) that you have fix-a-flat in it. I always hated opening a tire and having fix-a-flat juice splash into my shoes. It is an unsaid curtousy (sp?). Plus...buy that guy a Pepsi or tip him a few bux.
4. Have them clean the inside of the wheel out and it is usually a good idea to replace the valve stem while you are at it.
5. Don't use fix-a-flat ever again
PS. don't even ask me about that green "tire slime" crap
[Modified by SLPR, 8:35 AM 6/18/2002]
Old Jun 18, 2002 | 08:07 AM
HumanResource's Avatar
What tire size? You're in the Bronx, so I'd sstay away from anything larger than 15's. Trust me.
Old Jun 18, 2002 | 10:06 AM
Turbo Powa's Avatar
Default Re: Flat Tire WTF!!! (SLPR)
Thanks SLPR!!! Thats the best freakin reply I ever got on HT. Nice and detailed!!! Thanks alot!!!! I only have one problem the guy already repaired the hole with the Tee handle plug. from the outside in! what am I going to do now? He didnt even take the tire off my car. I also called Mavis Tire Discount and they want to charge me $30.00 to fix the tire from the inside and also balance it. I'm really starting to get nervous and pissed off. Should I just buy a new tire?
[Modified by Civic LX 29, 7:17 PM 6/18/2002]
Old Jun 18, 2002 | 10:53 AM
BROOD's Avatar
Hmmmm New York, I didn't think about that. There are no DTC's in NY. I can't believe I might say this but an NTB (National Tire and Battery) probably has patch tire repair and there should be some in NY. Otherwise call around and flat out ask how they repair tires.
Don't worry a tire that has been Tee plugged usually be re-patched correctly. I've redone many in my time. Just make sure they clean out the tire good. Just remember that sidewall holes can never be repaired safely!
~SLPR
PS. Thanks I try to be as helpful as possible.
[Modified by SLPR, 11:54 AM 6/18/2002]
Old Jun 18, 2002 | 11:25 AM
Turbo Powa's Avatar
THanks AGAIN!!
SI_you_later
Honda Civic (2006 - 2015)
14
Aug 23, 2007 06:28 AM
imroadk1ll
Honda Civic (2001 - 2005)
21
Feb 28, 2007 05:00 PM
funky49
Jun 1, 2003 11:59 PM
TypeR1558
Aug 11, 2001 11:58 PM
TypeR1558
Aug 6, 2001 07:21 AM
