Fixable?
I must be having a slow mental day here... that is the primary engine mount on the driver's side correct?
do the bolt holes look stripped to anyone but me?
that crack is not good but it's fixable. I'd have it welded personally.
two paths to repair.
weld up the crack, then carefully tap the holes to a slightly larger bolt and install.
weld up the crack, weld/fill the holes as well. Redrill and retap holes.
the second is the best idea but far from easy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">two paths to repair.
the second is the best idea but far from easy.</TD></TR></TABLE>
i agree with number 2. also id say no, on the internals. Ive never seen something like that before, Id make sure the crack didn't go spread. I use to have a 02' gixxer 750 with a broken off engine mount. welded it up, ground it down to look somewhat like it use to be (it was shiny) drilled & taped it. It was good as new. never had any problems again. you should be fine
u can weld that but is going to be weak and it might end up cracking again, that happened to my friends gsr and it was welded by a pro but it cracked again...if it was me i would get another block and save myself a headache..sorry
#2 is the best also.
#1 you will need to get a carbide bit and drill out a larger diameter on the mount as it's pressed forged steel and impossible to drill with any standard regular bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams »</TD></TR><TR><TD CLASS="quote">first ask your self is the block worth it </TD></TR></TABLE>
What are you smoking? It's not even a big deal. Have a welder fill in the crack for $50, then drill/tap the holes one step larger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spicyEM1 »</TD></TR><TR><TD CLASS="quote">JB weld the crank then JB weld the bolt, it will hold just fine.</TD></TR></TABLE>
shut up
JB weld will NOT hold that from cracking again due to the vibrations the engine endures
shut up
is funny how people waste their time talking ****, the block is not solid metal and the weld will be weak, like i stated before it happened to my boy and he weld the damn thing and it cracked again...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HNP »</TD></TR><TR><TD CLASS="quote">is funny how people waste their time talking ****, the block is not solid metal and the weld will be weak, like i stated before it happened to my boy and he weld the damn thing and it cracked again...
Considering that the motor/trans is held in with 5 mounts, and the mounts themselves dampen most of the vibration, recommending that he have it welded is not unreasonable advice.
He has a crack in 1 of about 15 bolt locations. Not exactly the crisis situation that would warrant spending hundreds of dollars to rip down the block and spend a week transfering everything over to a new block. He'd need a fresh hone, new rings, new bearings... what a nightmare. Just weld the ******* thing and be done.
</TD></TR></TABLE>Considering that the motor/trans is held in with 5 mounts, and the mounts themselves dampen most of the vibration, recommending that he have it welded is not unreasonable advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo Speed »</TD></TR><TR><TD CLASS="quote">Considering that the motor/trans is held in with 5 mounts, and the mounts themselves dampen most of the vibration, recommending that he have it welded is not unreasonable advice.
He has a crack in 1 of about 15 bolt locations. Not exactly the crisis situation that would warrant spending hundreds of dollars to rip down the block and spend a week transfering everything over to a new block. He'd need a fresh hone, new rings, new bearings... what a nightmare. Just weld the ******* thing and be done.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hks85 »</TD></TR><TR><TD CLASS="quote"> +
x2
edit: don't forget to helicoil that biznach. Ask any seasoned domestic guy, they will take a helicoiled hole over aluminum anyday. Good luck with it.
</TD></TR></TABLE>+
x2edit: don't forget to helicoil that biznach. Ask any seasoned domestic guy, they will take a helicoiled hole over aluminum anyday. Good luck with it.
White91EF
Nov 1, 2022 07:26 PM
alfmanforever
Feb 9, 2007 04:31 PM
maxspeedhonda
Oct 27, 2004 05:48 AM
