filling tranny fluid from the vss?
Old Apr 13, 2007 | 08:12 AM
92civicfreak's Avatar
Default filling tranny fluid from the vss?
my fill point is torqued shut.... i have a 90 si cable tranny is it possible if i pour some into this location? its not alot... probly less than 1/2 a quart
Old Apr 13, 2007 | 08:28 AM
havok hybrid's Avatar
Default Re: filling tranny fluid from the vss? (92civicfreak)
yes that is the way we all do it... pull the Vss .. add fluid... install Vss ... done.
Old Apr 13, 2007 | 08:29 AM
cool thanks
Old Apr 13, 2007 | 08:33 AM
1 more thing... i dont know what kind of fluid is in there now, would it be ok to use 10w-30 just to add alittle rather than only using $3 worth of a $6 bottle of MTF from honda? i'm planning to have it taken to a shop & have my tranny oil changed properly
Modified by 92civicfreak at 12:44 PM 4/13/2007
Old Apr 13, 2007 | 09:49 AM
anyone?
Old Apr 13, 2007 | 10:42 AM
ok, i have a crx w. a 90 si tranny, now to get to the vss, i have to take out my rear tranny mount... i would probly say i lost about 1/4 quart, probly less cuz it has only been dripping, i am only going to go down the street w/ my car do u all think it is ok to leave it as is? i am making an appointment w/ a guy at a shop to have the tranny oil switched next week & i'm unemployed now so i dont drive would it still be ok????
Old Apr 15, 2007 | 07:43 PM
Default Re: (92civicfreak)
Dude.. roll to jiffy lube.. tell them to "top off your tranny fluid" they will try to sell you on a bunch of ****.. just say no.. you just need to add some fluid.. it will cost you like 10 bucks ... maybe even free if they service writter is cool.
Or just pull the vss.. you dont have to take the mount off.. just a 10mm bolt .. remove the tiny plate that holds the vss in.. pull the vss out and add fluid.
Your tranny should be ok . if its only missing a minor amount of fluid.
Old Apr 15, 2007 | 07:57 PM
wtfizjdm's Avatar
Default Re: (havok hybrid)
also 10w30w is ok to use...
Old Apr 16, 2007 | 07:15 AM
Padawan's Avatar
Darth ModerVader
If the fill hole is stuck shut, how do you know you need fluid, and how do you intended to fill it to the correct level?
Old Apr 16, 2007 | 11:53 AM
Unsivil_audio's Avatar
Default Re: filling tranny fluid from the vss? (havok hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">yes that is the way we all do it... pull the Vss .. add fluid... install Vss ... done.</TD></TR></TABLE>
lol. I have NEVER done it this way. And I don't know of anyone who does. You would easily overfill the transmission doing it that way.
faster Type R
Honda Civic (2006 - 2015)
Nov 11, 2009 04:12 AM
o0Riffraff0o
May 14, 2009 08:51 PM
CaTiRo
15
Aug 31, 2004 03:18 AM
DSC
Jun 30, 2002 01:15 AM
