filling mounts with polyurathane? where to get it??
Old Feb 14, 2004 | 12:32 PM
92civeg's Avatar
Default filling mounts with polyurathane? where to get it??
im planning on getting es inserts, but i want to stiffen up my torque mounts a little too, ive heard you can use a tube of polyurethane, in like a caulk gun to fill them but i went to the hardware store today to try to find it and couldn't...anyone have a little more detailed description or pictures of what im looking for?
ive seen it on here before but i cant find the thread now
thanks- johnny
Old Feb 14, 2004 | 03:49 PM
func-tion's Avatar
Default Re: filling mounts with polyurathane? where to get it?? (92civeg)
I may be wrong but I think the es inserts come with everything you need to do all of the mounts.
Just fyi. Some of the people that run all of the inserts say that there car vibrates alot more after the complete install. I forget wich ones are less necessary.
Old Feb 14, 2004 | 04:00 PM
boost junky 71's Avatar
Go to Home Depot. They have what your looking for.
Old Feb 14, 2004 | 06:41 PM
torr's Avatar
Default Re: filling mounts with polyurathane? where to get it?? (e'sd16)
inlinefour sells energy suspension inserts for like 36 bux. they will make your ride vibrate.
Old Feb 14, 2004 | 06:51 PM
92civeg's Avatar
what is the polyurathene in a tube actually called and what is it used for....like around home depot...is it used for like flooring or what?
Old Feb 14, 2004 | 07:35 PM
Its in the same spot as the caulk. Just look you'll find it. Look at the tubes. It will say polyurethene. I believe the tube itself is black.
Old Feb 14, 2004 | 07:43 PM
blueintegra90's Avatar
its called 3m window weld and its in a white tube and will cost around 10 bucks. ur local auto parts store should have it and thats the only place i found it. i know they have other polyurathane but its not the same as the window weld
Old Feb 14, 2004 | 10:07 PM
92civeg's Avatar
Default Re: filling mounts with polyurathane? where to get it?? (blueintegra90)
which is better window weld or polyurathane??...anyone have a pic of the tube?
Old Feb 14, 2004 | 11:10 PM
mmuller's Avatar
Mad Scientist
3m window weld.
You can find it at most auto parts stores, its about 9 bucks
Old Feb 15, 2004 | 12:35 PM
92civeg's Avatar
Default Re: filling mounts with polyurathane? where to get it?? (mmuller)
ttt
Old Feb 15, 2004 | 06:38 PM
92civeg's Avatar
up i need a pic or exact name to look for
Old Feb 15, 2004 | 07:25 PM
its called 3m window weld. advanceauto parts carrys it or jsut go to advanceautoparts.com and look under chemicals and fluids. its under glue
Old Feb 15, 2004 | 07:38 PM
92civeg's Avatar
like this>???
or like this>???
Old Feb 15, 2004 | 08:08 PM
senpai's Avatar
there ya go willis
Old Feb 15, 2004 | 08:35 PM
Default Re: filling mounts with polyurathane? where to get it?? (maztur)
http://store5.yimg.com/I/levineauto_1775_2357118 there is a link to a picture of the bottle i bought.
Old Feb 15, 2004 | 08:45 PM
92civeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra90 &raquo;</TD></TR><TR><TD CLASS="quote">http://store5.yimg.com/I/levineauto_1775_2357118 there is a link to a picture of the bottle i bought. </TD></TR></TABLE>
cool..... thanks, i think im going to go with the window weld
Old Feb 15, 2004 | 08:47 PM
no problem
Old Feb 15, 2004 | 08:49 PM
92civeg's Avatar
which mounts did u fill?
Old Feb 15, 2004 | 09:10 PM
well i had just filled my front tranny mount and it was completly broke and putting it back ut sucked but when i did it i installed my tranny and clutch and flywheel the tranny was broke so i'm tearing it back apart this week and filling the motor mount and top tranny mount.
x19trix72x
Sep 15, 2008 05:41 AM
scabbs
Sep 17, 2007 09:57 AM
NUISANCE
Apr 20, 2007 06:00 AM
Scracho
Nov 18, 2005 03:51 PM
mugenintegra16
May 2, 2002 10:42 AM
