is there a write up on... mounts??
Old Sep 13, 2007 | 03:39 PM
scabbs's Avatar
Default is there a write up on... mounts??
ok I've been looking at a couple threds n ppl have been talking about filling (or sumthing) their motor mounts on their accords to make them stronger??? what do you fill them with and how would I go about doing this??? I would like to strengthin my mounts before dropping the h in... what all is needed and what needs to be done??? ne one have pictures by chance??? thanx lots guys
Old Sep 13, 2007 | 05:00 PM
Honda_Accord's Avatar
Default Re: is there a write up on... mounts?? (scabbs)
Try going motor mount inserts.. There is a write up about the filling but i cant seem to find it.
Old Sep 15, 2007 | 12:36 PM
scabbs's Avatar
Default Re: is there a write up on... mounts?? (Honda_Accord)
ne one know what to search for?? should I look up motor mount inserts again or look up filling motor mounts??? I jus didnt know if there was like a set write up on it err not... I jus kinda wanna try it too. are racing mounts better or is this way just as good???
Old Sep 15, 2007 | 01:40 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
you go to NAPA, Autozone..and buy a tube of Polyurethane..then you take your mounts and duct tape on side..fill them full of polyurethane it's really goopy..let them dry for a week because jsut because it looks cured the insides are still soft and will potentally squeeze the Polyurethane out...then BAM solid motorounts..the stuffs 13 bucks a tube...you'll only need one...GL on your swap man
Old Sep 15, 2007 | 11:14 PM
scabbs's Avatar
Default Re: is there a write up on... mounts?? (I got the CD5 Jeebies!)
like where do I squeeze the poly into... I was jus curious if you had like a pic mabey.. jus to point it out to me... Im sorry for being a pain in the *** about it though...
Old Sep 16, 2007 | 11:22 AM
AFAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">you go to NAPA, Autozone..and buy a tube of Polyurethane..then you take your mounts and duct tape on side..fill them full of polyurethane it's really goopy..let them dry for a week because jsut because it looks cured the insides are still soft and will potentally squeeze the Polyurethane out...then BAM solid motorounts..the stuffs 13 bucks a tube...you'll only need one...GL on your swap man</TD></TR></TABLE>
Polyurethan can range in hardness from a soft gelly like material, to a bowling ball. The stuff you're looking for is 3M Window Weld.
Old Sep 16, 2007 | 01:25 PM
oem_certified_accord's Avatar
Default Re: is there a write up on... mounts?? (AFAccord)
94-97 CD Honda Accord 5th Generation F series motor mount kit for 5 spd cars. OEM replacement. Set of 3 mounts. Driver side, transmission and rear mount. We also have a kit for the Auto to 5 spd conversion. Must use Accord F series rear bracket.
= Mr Wonderfull's People
Old Sep 16, 2007 | 01:35 PM
scabbs's Avatar
Default Re: is there a write up on... mounts?? (oem_certified_accord)
thanx guys and uhh mr wonderful... I have no idea how to pm ppl yet... lol all I know how to do is post... jus lemme know how n then I'll pm you..
thanx loads though guys
Old Sep 17, 2007 | 01:18 AM
under the date you joined under your "noob" sign u will see a little symbol that says IM.. click that and type away, that is what we call a "pm"
Old Sep 17, 2007 | 09:57 AM
scabbs's Avatar
alright thanx man.
alx_90ef
20
May 30, 2014 06:31 AM
Kaspk
17
Jan 19, 2008 06:54 PM
VtecFreePrelude
Feb 15, 2007 03:29 PM
Rod.
Jul 2, 2005 11:49 PM
Bbasso
Mar 4, 2005 05:48 PM
