Fast engine swap/change help!!
Old Apr 15, 2004 | 06:47 PM
DJcaseychaos's Avatar
Default Fast engine swap/change help!!
I have a 90 civic Dx 4dr. Thats like a D15? none vTec 1.5L SOHC. Nothing speacial, I want to put somthing newer in but I still need the car to get around for school and work and stuff like that...... What can I put in With out changing or making big mods fast? I was told just to get a newer D15 and try that but, They have vTec and my ECU will have to be changed....I dont know if all the wires will reach and how long that will take to change the ECU. What can i do?!?!?!?
Old Apr 15, 2004 | 08:46 PM
Default Re: Fast engine swap/change help!! (DJcaseychaos)
Come on pros.....wats up were ya at?
Old Apr 15, 2004 | 09:02 PM
dmotoguy's Avatar
in the hybrid forum
Old Apr 15, 2004 | 09:11 PM
Default Re: Fast engine swap/change help!! (dmotoguy)
What?
Old Apr 15, 2004 | 10:21 PM
XSIintegra's Avatar
I hate to do it, but search. There is a lot you can do. Its all money and time......
Old Apr 16, 2004 | 08:23 AM
Sliced Beard's Avatar
Default Re: (XSIintegra)
first of all there is no vtec on any d15 unless you get a d15b from j-pan
and second, a mildly easy swap would be a d16a6 (si engine)
all you would have to do is run three wires for VTEC and get the ecu and you're set
Old Apr 16, 2004 | 08:51 AM
eRACING's Avatar
Default Re: (dirtyd463)
Just wire in VTEC if your installing a vtec motor.. two wires... VTEC Pressure Switch and VTEC Solenoid wire...
Old Apr 16, 2004 | 09:49 PM
Well the problem is need to get this done over the weekend!!! This has to be quick.....but yet while I got the chance I want an upgrade... So The D16a6 you think would be best......
Jackwj5
Jan 21, 2017 05:35 PM
wolf95
16
Sep 5, 2010 08:25 AM
4 door beast
Mar 3, 2009 10:47 AM
wzachmorris69
Nov 6, 2006 12:26 PM
jjyynnxx
Aug 10, 2006 09:06 AM
