Failed Emission Help
Old Aug 17, 2004 | 08:43 AM
x00gsr's Avatar
Default Failed Emission Help
Yes, I've did a search. Heres a list of what i've done
*tune up
*Installed new O2 sensor
*seafoamed the engine
*installed new cat
*new evap canister
*retarded the timing
My HC reading is still too high. Co and Co2 is fine.
Would a bad head gasket or ring cause HC to go up as well?
Modified by x00gsr at 5:55 PM 8/17/2004
Old Aug 17, 2004 | 09:27 AM
x00gsr's Avatar
Default Re: Failed Emission Help (x00gsr)
ttt..help anyone??
Old Aug 17, 2004 | 01:20 PM
xEnderx's Avatar
Did you fail at idle, or at the other two RPM ranges.....plus how exaclty did they test you?
If you give me the right info I should be able to help you figure out whats wrong. I am a certified emmisions tester and gas analyzer operator.
Old Aug 17, 2004 | 07:21 PM
dfoxengr's Avatar
Default Re: Failed Emission Help (xEnderx)
get some "guaranteed to pass" from NAPA>..
Old Aug 17, 2004 | 08:50 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Failed Emission Help (hybridvteceg)
probably new cat. Is it a nice one (was it expensive, aka more than 180 bucks)?
Old Aug 17, 2004 | 09:20 PM
AngryTroll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x00gsr &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I've did a search. Heres a list of what i've done
*tune up
*installed new cat
*new evap canister
Modified by x00gsr at 5:55 PM 8/17/2004</TD></TR></TABLE>Yes, a head gasket or bad rings will increase HC. Does the engine run bad or does it smoke?
You need to post your e-check numbers. If HC is only a little high, a fresh QUALITY converter will almost guarantee a pass.
Old Aug 17, 2004 | 09:30 PM
eda6's Avatar
Default Re: Failed Emission Help (AngryTroll)
if you failed the idle test here's a tip.
increasing idle speed will lower hc's a bit.
out here the max rpm during idle test is 1100.
I failed because of a clogged cat and gave the guy $100 to make it pass.
He increased my idle to 1075. finally passed.
$100 to turn a screw
what is "seafoam"?
Old Aug 18, 2004 | 07:36 AM
x00gsr's Avatar
Default Re: Failed Emission Help (eda6 hb)
HC standard is 220 and my hc reading was 371 first time and 336 second time.
Tried the Guaranteed to pass stuff also. No and im not seeing any smoke or loss in power due to head gasket or rings. How do you know if your dizzy is bad? Oh yeah and all this is in a b16a3. Max idle rpm is 1100. COnditioned at 2500 rpm.
Old Aug 18, 2004 | 10:27 AM
AngryTroll's Avatar
You didn't fail that bad. I've seen HC much higher. Fresh oil will lower your HC a little and a fresh converter will work wonders.
Old Aug 18, 2004 | 11:22 AM
tegon-gsr's Avatar
i have the same problem around how much would it cost to fix these to problems if it was the problem "head gasket and rings" i got some cam work done about a year ago and i was talking to some guy and he told me that might be the problem.
Old Aug 18, 2004 | 08:10 PM
blueeg's Avatar
Default Re: Failed Emission Help (tegon-gsr)
check your map sensor, fuel pressure, injector for leakage, coolant temp. sensor. thats all i can think of for now. U do anything mods to your computer?
Old Aug 19, 2004 | 09:05 AM
x00gsr's Avatar
Default Re: Failed Emission Help (blueeg)
Did the oil change. Map sensor is good. No check engine light. Distributor cap and rotor are new. No vacuum leaks anywhere. No mods to computer. Im just going to take it to a mechanic.
Old Aug 19, 2004 | 02:16 PM
dfoxengr's Avatar
get that stuff i posted above/
Old Aug 19, 2004 | 07:31 PM
taz77's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">get that stuff i posted above/</TD></TR></TABLE>
he already did that...
eklum
Jan 7, 2009 10:01 PM
SlimDC5
Apr 25, 2008 08:53 AM
cornflakes
22
Sep 24, 2007 10:07 AM
mintscorpion
19
Jan 20, 2006 04:27 PM
Ge.ES.AHH
Oct 10, 2004 11:21 PM
