A/F tuning with A/F guage?
Old Mar 30, 2009 | 04:58 PM
ad-8's Avatar
Default A/F tuning with A/F guage?
Ok, let me start out by saying, I bought a cheap A/F gauge just to see if my car was running rich/ lean not to try and fine tune it. Anyways, come to find out my car runs rich pretty much all the time, I do have a B&M adjustable FPR, which I fiddled with, but the gauge doesn't ever change in sync with my adjustments. Is it possible to lean out the car too much and the gauge won't show it? If anyone could just fill me in a little that would be awesome.
Also I assumed that if you turn the FPR counter clockwise thats making the a/f leaner?
Setup:OBD-0 b16, CTR cams, IM, TB, exhaust, intake
Old Mar 30, 2009 | 05:04 PM
turbostd's Avatar
Default Re: A/F tuning with A/F guage?
You need a wideband tuning with a narrow band gage wont work.
Old Mar 30, 2009 | 05:28 PM
mar778c's Avatar
Community Builder
Community Influencer
^^^This correct.
You can chip your PR3 or PW0 computer and use BRE to tune.
Old Mar 30, 2009 | 08:03 PM
blakcivicsi's Avatar
Lemme get this right.. your attempting to do some "tuning" to your car by adjusting your fuel pressure regulator and watching your narrow band? If so you need 3 main things.. a good engine management system like Hondata, a good wideband air/fuel gauge, and a professional tuner. Tuning is probably the most important part of your build, do not mess around with it.
Good luck w/ everything, you don't have a bad little setup there.
Old Mar 30, 2009 | 08:38 PM
TorganFM.'s Avatar
Old Mar 30, 2009 | 11:00 PM
ad-8's Avatar
Ok, I need a wideband, that I understand, but why doesn't my guage reflect when I adjust my fuel pressure?
Old Mar 31, 2009 | 12:40 AM
ddd4114's Avatar
It's just going to be a light show.
Old Mar 31, 2009 | 11:03 AM
Flashmn's Avatar
Fail...
NVM I cant read... :D Anyways, adjusting mixture with fuel pressure is very silly...You'd do it with fuel maps.
Old Mar 31, 2009 | 04:15 PM
Originally Posted by TorganFM.
Oh because Hondata, like an S300, is complete junk. Wonder what you have to say about all the cheapskates running freeware software setups on they're half *** setups.
To the OP, your narrow band isn't going to reflect much of anything honestly, except like ddd4114 said, a mostly random output of lights. Sell the narrowband and get a good wideband and the rest of the parts to be able to have your car properly tuned by a professional.
Best of luck
Old Apr 1, 2009 | 07:58 AM
RC000E's Avatar
A narrow bands purpose is to allow the ecu to stabilize air/fuel at idle and part throttle modes. A narrow band was designed to indicate stoich (14.7:1) and really nothing more. Under wide opened throttle, a motor that is n/a or forced induction will always need more fuel than stoich would allow in order to make peak power, essentially making your narrowband gauge always read rich. The last thing you want to do is globally reduce the amount of fuel the motor sees by reducing fuel pressure. Stop what your doing.
Narrowband gauges are nothing more than lightshows and to fill the pillar pod. Your space is better filled by an autometer clock gauge so you can tell what time it is.
Old Apr 1, 2009 | 09:28 AM
Ls_dx's Avatar
lol. words of wisdom
Old Apr 1, 2009 | 09:54 AM
ddd4114's Avatar
Even better, go on the computer and print a picture of an Autometer gauge. Then, just cut it out and attach it to the pod with a glue stick. It will be just as useful and will cost much less.
JDM_ego2033
Engine Management and Tuning
Apr 23, 2018 05:16 AM
prelude_problems
May 30, 2009 06:21 PM
jarven093
Jul 20, 2007 11:48 AM
nightkid1
Jun 3, 2007 10:05 AM
PM-Performance
Mar 28, 2003 02:12 PM
