Failed Smog.... :[
Old Mar 30, 2009 | 06:37 PM
fcjohnny's Avatar
Default Failed Smog.... :[
I bought a 91 Civic Sedan that failed smog :[ but w.e I didn't care I bought it for 400$ :].. Ok so the paperwork from the smog place said the following:
Comprehensive Visual Inspection: Tampered ( I'll explain why below )
Functional Check: Fail
Emissions Test: Pass
On the emissions control systems visual inspection/ function check results said it failed on the following:
Fuel Evaporative Controls Functional : Fail
Fuel Cap functional : Fail
The tampered part was because the previous owner went and cut the air tube in half and threw a kn filter on it. Well I went have replaced everything with the stock intake so thats all good.
As for the fuel cap I'm gussing I need to go buy a new one since this one isn't sealing?
Anyone have some advice? I'll be going by the place he had it smogged at so they can clear all this **** up for me and get re smogged :]
Old Mar 31, 2009 | 05:54 AM
lponcian5799's Avatar
Default Re: Failed Smog.... :[
what state do you live in? i know here in MD, some people pull the bulb for their check engine light and SLAM their cars on coilovers, MD will automatically wave you because car is too low to go on the rollers, automatic 3 year extension
Old Mar 31, 2009 | 08:25 AM
fcjohnny's Avatar
This is out here in Cali. They gave me a 2 month extension but at the end of april is when my extension ends...
Old Mar 31, 2009 | 08:43 AM
PhongN's Avatar
just replace the gas cap and you will be fine...
Old Mar 31, 2009 | 09:52 AM
thesmogman's Avatar
Yes, the gas cap failed. Didn't he explain this to you? So replace it.
EVAP test.(LPFET) This test's the gas tank and Carbon cannister's line for any leaks. Going by your explanation this is the other thing you failed on or you have disconnected/removed the cannister.
The intake tube has nothing to do with the EVAP controls.
If it was the LPFET test you failed let us know and I can give you more info on how to fix it.
Old Apr 1, 2009 | 10:05 AM
fcjohnny's Avatar
also says that I'm missing some switch and sensors too. The guy never explained this to me because I wasn't the one who had it smogged it was the previous owner who did.
RicoP
Northern California
Oct 13, 2010 04:56 AM
IntegType7
Jun 29, 2010 09:19 PM
Inextricabledrvr
Jul 1, 2009 09:43 AM
Vanilla4215
Jul 2, 2002 04:33 PM
