Shifting problem (need info)?
Old Jan 22, 2002 | 10:34 AM
AmauryR's Avatar
Default Shifting problem (need info)?
Hey whats up, I'm having some tranny problems in my '93 Si and I dunno what could be causing the problem:
#1 Car doesn't like to go 1st->2nd (gear shift "holds" itself in neutral for a while untill I pu into gear, happens a lot)
#2 Car grinds frequently into 3rd (I thought it was a psyc. problem, but I held down the clutch all the way and it did it, happens atleast once a day)
#3 Car grinds into reverse (in mornings and when backing up, happens a couple of times a day)
#4 Car falls out of 3rd (I would be cruising and gear would pop into neutral, happened a couple of times)
#5 After like #2 or #3 happens, I get this terrible smell comming from my car (when I have the vents/sunroof open), smells kinda like oil burning.
I'm working on a motor to swap into the car (b-series), and I can see there being some problem with my tranny, but I would like to know if there's a way to check if my master/slave cylinder is failing beause I'd have to reuse them with my swap and I wouldn't want that to fail on me.
BTW- The car is a '93 Civic Si (sohc vtec) w/ approx. 148k mi
Old Jan 22, 2002 | 10:57 AM
DR. ON POINT's Avatar
Banned
Default Re: Shifting problem (need info)? (SKiLLz-R)
I know when I got my first car it was realy hard to put into all the gears...the springs in the clutch were all broken...ur clutch might be getting ready to go....but my car never popped out of gear...that is realy weird...u dont have synchros in first gear or reverse...I dont know what else to say but hurry up on ur swap before ur tranny/clutch goes out
Old Jan 22, 2002 | 11:15 AM
AmauryR's Avatar
Default Re: Shifting problem (On Point EK)
Yeah, I'm almost ready 4 my swap, jus shoppin around for a clutch - looks like exedy for my b-motor. But I wanna c if I can "guestimate" on how bad my tranny is, so I can see if I'll have to "rush" my project
jdmej2lolo
Oct 17, 2008 09:13 AM
Snowblaizer
Jul 2, 2007 01:52 PM
integra4991
Jan 13, 2005 05:52 PM
RsxVengeance
Oct 12, 2004 12:16 PM
thugfolife2
12
May 3, 2004 05:42 PM
