experienced tuners:help
Old Aug 18, 2004 | 04:37 PM
johnzm's Avatar
Default experienced tuners:help
i have been fighting an issue for a little while now.
the car is running rich.
i had a wideband on the car, when i start cruising, it will drop belo 7:1
all 4 of my plugs are fouled out
when WOT its 13.5:1 and when accel is good
i have a chipped ECU with 2 chips
i started the car with the old chip in there and u could see smoke hardly puffing out (black smoke) at idle. i swapped chips and its still doing the exact same thing.
if i unplug my o2 or plug it in its doing the same thing
i have no clue whats ding it, but i have been having this issue for a long time now.
someone help me out or point me in the right direction.
PWO chipped
b16
JDM 4-1 with heated o2 at the bottom
tried it 1,2 o2 wire to 1, one o2 to #1 wire no #2, and no 02 at all. all the same result at idle
Old Aug 18, 2004 | 05:32 PM
MAD B16's Avatar
Default Re: experienced tuners:help (johnzm)
I am no honda expert but to me it sounds like your o2 is bad. if you unpluged it and it started acting up that would lead me to think that the sensor was good but since you unpluged it and nothing happened it would make me think that the sensor was bad. just my 2 cents. maybe it will help.
Old Aug 18, 2004 | 05:34 PM
91civicDXdude's Avatar
have you tried looking at the fuel tables? maybe it is just having too much pulsewidth at low rpm..
Old Aug 18, 2004 | 05:40 PM
Sliced Beard's Avatar
Default Re: (91civicDXdude)
7:1 HOLY CRAP....it runs with that much fuel?!?!?!?
there is something definately wrong with your o2 sensor or connection
Old Aug 18, 2004 | 06:27 PM
johnzm's Avatar
Default Re: (dirtyd463)
i just tried a different o2 but cannot get anything out of it.
lemme assk u, since i reset the ECU its long term trims should be reset too right?
becasue this thing iss running the same no matter what i do to it grrr
im gonna get a new 02 of its not too much tomorrow. its an obd0 car that im wiring for a heated o2
Old Aug 18, 2004 | 09:59 PM
lemongreenhatch's Avatar
Default Re: (johnzm)
i have same problem with my b20/vtec i think i have a bad o2 i tried to hook up air fuel gauge but it doesnt read any thing so i put a fuel pressure reg. and gave it less gas it stopped smoking and my spark plugs stopped getting full of carbon and fouled but know it bogs on accel. like it running lean ima try changing o2
Old Aug 19, 2004 | 08:43 PM
johnzm's Avatar
ttt any more help here?
someone reccomended the mugen chip can anyone tell me what it does
bigmikey7351
Jun 3, 2008 09:01 PM
johnzm
10
Apr 12, 2003 06:59 AM
IloveNewt
Mar 24, 2003 12:53 PM
VTC_CiViC
Jul 16, 2002 07:33 AM
