Exhaust temps
Old Sep 20, 2004 | 06:27 PM
BrianZ's Avatar
Default Exhaust temps
I'm working on a 89 CRX si for a friend. This car is a future HC race car. We are slowly modifying it as he does HPDE's and gets his skills up to HC levels.
The problem I noticed what when we dynoed the car I noticed that cylinder #3 at the header was 40-60deg F hotter than the others .. it seemed the average temp was 260.. #3 was at 300+. If I'm correct this indicate that cylinder # 3 is running lean. I can't seem to figure out why tho.
This motor has 121K miles. Brand new cap and rotor. Injectors have been cleaned and balanced. Very recent valve adjustment.
Any idea's? anyone else run into this problem?
here is a pic, you can see the difference in the color of the header
Old Sep 20, 2004 | 06:32 PM
d16rice's Avatar
Default Re: Exhaust temps (95tegLSS)
maybe the injector is bad?
Old Sep 20, 2004 | 07:23 PM
sledgehammer's Avatar
Default Re: Exhaust temps (d16rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice &raquo;</TD></TR><TR><TD CLASS="quote">maybe the injector is bad?</TD></TR></TABLE>
If the injector is bad the cylinder would usually run cooler and when you hit it with an IR gun you'd see that that cylinder is dead. #3 is usually the cylinder that will run the hotest.
Mike
BrianZ's Avatar
I had moved #2 and #3 injector and re-tested. The problem did not move. I then sent the injectors out to have them cleaned and balanced (sent to RC engineering). I'm confident that is not the problem..
I'm leaning towards a bad valve adjustment. I'm going to do a compression check later this week..
Old Sep 20, 2004 | 07:24 PM
BrianZ's Avatar
Default Re: Exhaust temps (sledgehammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sledgehammer &raquo;</TD></TR><TR><TD CLASS="quote">
Mike</TD></TR></TABLE>
Is this common on a D block only? my B18 has pretty even temps...
mortificationrock
Mar 26, 2008 12:01 PM
.BigSexy
May 19, 2007 10:54 AM
ek4__
Apr 12, 2007 04:42 PM
magic hat #9
Sep 19, 2003 08:23 AM
JohnShaft
Sep 5, 2001 02:01 PM
