having problems with #2 cylinder please help
im not sure why but cylinder 2 is not working. when i pulled the spark plug wire out it still ran the same. change the wires nothing, spark plug nothing, injector nothing, tested the the harness for #2 injector and still getting a reading 12v i think, compression still good 190, and replace the dizzy during the winter. im stuck on this one! please help or give me some ideas to what may cause this..
Re: having problems with #2 cylinder please help (ek4__)
u may have a bad injector, just because it has pulse doesn't mean that it has flow, try switching injectors 1 and 2 to see if problem moves to cyc 1
Re: having problems with #2 cylinder please help (19slocivic97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19slocivic97 »</TD></TR><TR><TD CLASS="quote">u may have a bad injector, just because it has pulse doesn't mean that it has flow, try switching injectors 1 and 2 to see if problem moves to cyc 1</TD></TR></TABLE>
already tried that with a different injector. still the same. could it be the valve clearnce is too big?
wouldnt be a valve if your comp was 190... sounds like a computer prob, maybe an injector driver(the ECU grounds the injectors to make them spray fuel, having 12 volts means nothing). have you even checked for for spark and fuel in that cyl and not just throwing parts at it? its one of those two things if you have compression.
Re: having problems with #2 cylinder please help (APCforthewin)
thanks for th help guys but it turns out that #2 injector is working but not flowing to well anymore.
i figure i might as well try again and well and behold # 1 cylinder went bad so. i know its the injector and nothing else.
i have obd 2 gsr injectors laying around would that work for my sohc?
ok forget that all of them dont work anymore from sitting around for 3 yrs now. i guess ill just go get a new one from autozone
OrangeBoost
05-30-2006 10:22 AM
