Erratic idle situation
Old Nov 12, 2001 | 09:07 PM
eternal21's Avatar
Default Erratic idle situation
Motor-B16A2
Symptoms - high idle when cold, erratic idle when warm; erratic as in it revs to about 2500, then back to about 700, then 2500, then back to about 700 over and over and over, etc.
Replaced - EGR, MAP, IAC
Reset - ECU
CEL code - (Check Engine Light) none
I'm thinking it HAS to be a vacuum leak somewhere, but there's nothing visible, nor is there anything I can hear. I'm about at the end of my rope. Any suggestions?
Old Nov 12, 2001 | 09:11 PM
Type Goch's Avatar
New User
Default Re: Erratic idle situation (eternal21)
have you tried checking out your throttle body and other seals and what not?
Old Nov 12, 2001 | 09:21 PM
eternal21's Avatar
Default Re: Erratic idle situation (Type Goch)
Yes.
Old Nov 12, 2001 | 09:35 PM
Type Goch's Avatar
New User
k.
Old Nov 13, 2001 | 07:58 AM
eternal21's Avatar
ttt
Old Nov 13, 2001 | 08:11 AM
REDBARON's Avatar
Are you sure the ECU is not throwing any codes? Just because the CEL is not on doesn't mean that there isn't a code that it's throwing.
Old Nov 13, 2001 | 08:54 AM
djpuffball's Avatar
New User
aight i kinda have the same problem because my car would sit idle at 1000 and now its below and it just moves around while sitting there.
Not alot but it does.
Also there is like a whining noise coming from my engine when i turn on my car and rev.
Please help
Old Nov 13, 2001 | 08:58 AM
djpuffball's Avatar
New User
Default Re: Erratic idle situation (VTECHatch)
my car i think is doing the same thing i have a 97 civic and i used to idle at 1000 and now it sits at under 1000 and then goes up sometimes.
My car is also making a funny whining noise when i turn it on and when i rev.
PLEASE HELP
eternal21's Avatar
I jumped the ECU and left it for more than 10 mins. It never blinked. No codes. It stayed on and solid the entire time. So yes, I am POSITIVE there are no codes.
Old Nov 13, 2001 | 09:02 AM
eternal21's Avatar
Default I don't think we have...
...the same problem. When I say it goes up and down, imagine yo-yoing. Now, transfer that over to my car's idle. This is not a sometimes issue, this is an ALL THE TIME OCCURRENCE.
Old Nov 13, 2001 | 09:12 AM
REDBARON's Avatar
Default Re: I don't think we have... (eternal21)
Yeah, I know what you're talking about. My brother had the
same problem on his 88CRX si. The dealership said that it
was probably the EACV that was bad or clogged. But after
I had the speedometer gear replaced since it wasn't working
I just reset the ECU and it stop doing it. So I'm
not sure what was making it do that. My codes were: VSS,
Ignitor. Sorry I can't help you any further.
Old Nov 13, 2001 | 09:28 AM
eternal21's Avatar
Default Someone suggested to me...
...that I should replace the "FITV...its the thing thats bolted on the bottom of the throttle body...has 3 bolts"
so, since this was the only thing that wasn't replaced, I'll try that tonight.
92bseries
Dec 7, 2011 12:59 PM
got00rice
Dec 30, 2009 12:16 PM
mafay2
Jul 13, 2005 11:52 AM
crexer
Jan 15, 2005 09:46 PM
