erl girdle???
Old Dec 19, 2007 | 03:37 PM
BILLY_BLING's Avatar
Default erl girdle???
what is the TQ of the erl girdle????
Old Dec 19, 2007 | 03:59 PM
Mikey3000's Avatar
Default Re: erl girdle??? (BILLY_BLING)
what is TQ?
Old Dec 19, 2007 | 04:42 PM
Lubo_25's Avatar
what is the torque you mean??
Old Dec 19, 2007 | 07:25 PM
yes torque is what I mean
Old Dec 20, 2007 | 04:21 AM
Mikey3000's Avatar
Default Re: (BILLY_BLING)
your question still doesn't make any sense. regroup and try asking again.
Old Dec 20, 2007 | 05:18 AM
Lubo_25's Avatar
to answer your question there is no torque for the erl girdle...
your torque will vary depending on what bolts/studs you choose to use
Old Dec 20, 2007 | 12:35 PM
the block I got has arp studs, Do you torque them the same as stock to 60 ft.pounds
Old Dec 20, 2007 | 01:57 PM
Lubo_25's Avatar
no if you have stock main bolts you use stock torque whats the point of the higher clamping loads from the arp's if you use stock specs??
second was the girdle correctly dowelled for movement resistance??
and third was the block align honed properly to the crank centreline??
because otherwise this girdle wont do its job as intended...
Old Dec 20, 2007 | 05:58 PM
yes the block hade all of those things done erl sent me a build sheet and they torque the bolts to 70foot pounds
Old Dec 20, 2007 | 07:39 PM
Lubo_25's Avatar
so if you know what the torque is then whats the problem?? it's time to make your clearances
Old Dec 21, 2007 | 08:10 AM
Darton's Avatar
Here's a thought? Call ERL - (800) 831-9510
Old Dec 21, 2007 | 09:19 AM
Lubo_25's Avatar
Default Re: erl girdle??? (Darton)
haha well yes theres that option but if he recieved the specs from erl after the machining processes i dont know why this thread was made to begin with thats what im getting at...anyways cheers comrades
Old Dec 21, 2007 | 07:30 PM
they had just sesnt me the info today, but I asked a week ago
Old Dec 22, 2007 | 05:21 AM
Lubo_25's Avatar
well then my friend everything is good to go
Old Dec 22, 2007 | 08:03 AM
scott0's Avatar
mine came with the arp main studs and had the torque specs machined into it.
vti_civ
Jan 24, 2019 02:23 AM
djtony5
Nov 17, 2005 02:48 PM
SupaFly_Honda
Aug 11, 2004 07:09 PM
leadfoot78
May 3, 2004 07:11 AM
