Engine wont start, help!!
Old Feb 12, 2005 | 06:38 PM
92HB_HB's Avatar
Default Engine wont start, help!!
I recently took off my timing belt so i could get to my head studs and retorque them down.. (fyi, this is my gsr turbo motor)
After I got everything back together, i went to crank the motor, but it wouldn't start.. it kinda sounded like my timing belt was off a few teeth.. Also, it did not sound right when it was cranking.. but I"ve double and triple checked it and its perfect.. aligned the white TDC mark on the pully w/ the indicator on the timingbelt cover and also aligned the marks on the cam sprockets.. I did this a few times and the car would still not turn over..
ive even replaced my plugs, checked for spark, and fuel pressure..
I need help!!
Munkeyjdm86
Feb 4, 2014 07:21 AM
sunnyutahsky
Aug 10, 2013 06:32 PM
Lao17
12
Aug 2, 2011 01:49 PM
green_si
18
Mar 3, 2010 03:24 PM
lt1guy
Feb 14, 2010 07:06 PM
