Engine Missing
Car is a 91 crx si w/210000 miles. I just changed the plugs, cap,rotor, and igniter.
It idles at about 1100 rpm and its missing. Anything over idle it's fine. What are some things that could be causing it to miss at idle?
Thanks in advance.
Thanks in advance.
Lol how'd I miss this one... must have been my long day at the shop. What's your ignition timing at? I bet that's your problem. If you don't have a timing light just loosen the 3 12mm bolts a little (just enough so you can rotate the dist.) start it up and then rotate the distributor until the idle evens out.
16 degrees below top dead center. Here's the only pic I could find online to show you:
in fact there's a whole write up here: http://www.c-speedracing.com/h...g.php. And yes sohc timing is the same as dohc.
bassysingh
Oct 17, 2005 10:02 AM
