Engine lock up due to lack of oil
Old Feb 26, 2004 | 09:17 AM
dominate9's Avatar
Default Engine lock up due to lack of oil
When an engine runs out of oil and it locks up, what are some things that could happen to the engine?
Old Feb 26, 2004 | 09:40 AM
HT Chaplain's Avatar
Loved
Default Re: Engine lock up due to lack of oil (dominate9)
everything can melt together to form one solid block
Old Feb 26, 2004 | 10:17 AM
simplestyles's Avatar
rip it out and use it for a boat anchor its toast
Old Feb 26, 2004 | 12:14 PM
E.G.6's Avatar
well, you're sure gonna stop moving fast for one...there's gonna be a real lovely smell...oh, and alot of burning too...
Old Feb 27, 2004 | 05:05 AM
dominate9's Avatar
So would all the internals need to be replaced or are there some that would have survived?
Old Feb 27, 2004 | 05:12 AM
JimBlake's Avatar
Take it apart & see. That doesn't guarantee anything. Maybe the rings scored the cylinder walls, but the pistons, rods, & crank are OK. Maybe some of the bearings are shot. Guaranteed WE aren't gonna be able to tell you because we can't see it from here.
Old Feb 27, 2004 | 05:34 AM
8200RPM's Avatar
local hippie
show us pics! i wanna see what happened.
Old Feb 27, 2004 | 12:31 PM
MightyMouseTech's Avatar
Default Re: Engine lock up due to lack of oil (8200RPM)
I bet you can reuse the oil cap.
Old Feb 27, 2004 | 12:55 PM
dominate9's Avatar
Default Re: Engine lock up due to lack of oil (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">I bet you can reuse the oil cap. </TD></TR></TABLE>
Ha Ha. Good one! No wonder they call you Mighty!
Old Feb 27, 2004 | 10:14 PM
Nhilcrest's Avatar
I actually had this happen to my 94 accord. What happened was the cam melted to the head.
Old Mar 1, 2004 | 04:01 AM
JimBlake's Avatar
Default Re: (Nhilcrest)
I had it happen a long time ago with my college beater car. I put oil in the spark plug holes, let that sit for a day or 2, then I could turn it with a wrench on the crank pulley. After lots of oil in the cylinders, & cranking, I put the plugs back in & it ran.
Within about a year I decided to overhaul it. I got new rings & honed the cylinder walls. I got new bearings, but when I took it apart the bearings actually weren't damaged. It ran for another 80k miles or so before I sold it.
You aren't gonna know how extensive the damage is until you take it apart & look.
Old Mar 1, 2004 | 04:29 AM
dominate9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nhilcrest &raquo;</TD></TR><TR><TD CLASS="quote">I actually had this happen to my 94 accord. What happened was the cam melted to the head. </TD></TR></TABLE>
What did the mechanic do to fix it? How much did it cost to just it fixed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I had it happen a long time ago with my college beater car. I put oil in the spark plug holes, let that sit for a day or 2, then I could turn it with a wrench on the crank pulley. After lots of oil in the cylinders, & cranking, I put the plugs back in & it ran.
Finally, a success story. I'm going to try that as well. My car is at a performance, but they haven't looked at it yet. So i guess what you did would be a good first step.
jdm.boi408
Feb 8, 2011 07:24 AM
Paprika
Nov 23, 2008 04:01 PM
Rain_man
Jun 20, 2002 03:42 PM
