engine harness question... I searched!!!
Old Jan 2, 2005 | 04:50 PM
pazdeniro's Avatar
Default engine harness question... I searched!!!
Hi, to all... can i use a 2000 ex wire harness with a 98 d16y8 and a 98 p2p ecu? i search for a while and couldnt find the info... thanks
Old Jan 2, 2005 | 09:35 PM
slomofo's Avatar
GDD Member
yes
Old Jan 2, 2005 | 10:01 PM
frankist's Avatar
I believe so.
Old Jan 3, 2005 | 04:31 AM
pazdeniro's Avatar
Default Re: engine harness question... I searched!!! (pazdeniro)
good morning bump!!
Old Jan 3, 2005 | 05:55 AM
pazdeniro's Avatar
any one else? i need a definite answer!!!
Old Jan 3, 2005 | 07:18 AM
pazdeniro's Avatar
a help me bump!!!
Old Jan 3, 2005 | 08:34 AM
civic-4-ges's Avatar
No you can't!!!
You can use a 2000 EX harness with a 1999-2000 ECU, but you cannot use a 2000 harness with an ecu earlier than 1999.
Why?? Because of the plugs thjat the ecu used at the ecu end of the harness. There is 1 different plug between the 1996-1998 as compared to the 1999-2000 ecu's
You can check out the Hondata sight which will illustrate the difference between the obd2a and obd2b ecu's
Torleif
10
Aug 20, 2015 05:29 AM
NCSHERO
Aug 24, 2012 10:58 AM
99EeeKay
Dec 14, 2009 02:49 PM
k20rockstar
Mar 30, 2009 08:31 PM
Dan-R
Feb 25, 2009 12:35 PM
