engine harness
Old Apr 19, 2004 | 10:48 PM
Blanket Jackson's Avatar
Default engine harness
i have a 96 civic hatch back and it doesnt have an engine harness. i am putting an ls vtec engine in it and i was wondering what engine harness should i get. should i get just the stock 96 engine harness or should i get a 99-00 civic si engine harness
thanks
Old Apr 20, 2004 | 08:33 AM
VtecDeMoN's Avatar
Default Re: engine harness (HONDAofPOKY)
Well you don't specify which model of civic you have, I'd suggest getting the 99-00 Si if there is one available, if not just wire the stock one up... not too hard to do and plenty of resources online.
Brian
Old Apr 20, 2004 | 09:06 AM
turbo*s2k's Avatar
Default Re: engine harness (VtecDeMoN)
I would go with the stock one and modify that one. An Si harness is going to cost around $150+
Old Apr 21, 2004 | 11:14 AM
The car is a CX hatch. It no harness what so ever, it was ripped out when the car was stolen. I also don't have a harness for the LS-VTEC going into it. That car is long gone. So the SI is the best bet? Going with Hondata management.
Old Apr 22, 2004 | 12:50 PM
Grimace EJ6's Avatar
Default Re: (HONDAofPOKY)
you cannot use a 99-00 SI harness in a 96 car. unless that is u have all the dash wiring and components switched to 99-00 spec. ur best bet is a 96-98 civic EX harness, good luck finding one, i been searching for months
Old Apr 23, 2004 | 07:23 AM
I actually had one for a few days, then I had to send it sway to get spliced with an H22A harness to run H22A in a friends 96-98 EX Coupe.
enigma94
Sep 29, 2007 05:42 PM
Katman
Aug 12, 2007 04:57 AM
ek_will
Apr 28, 2007 11:08 AM
Slava.
Jun 13, 2005 08:57 PM
Silverbeast
May 14, 2003 11:07 AM
