engine code help
Old Oct 15, 2002 | 01:02 PM
kuelerz's Avatar
Default engine code help
okay i finally checked the codes on my car and i only have three codes:
Code 4:Crankshaft position senser
Code 7:Throttle position
Code 41: o2 senser
well amazingly when i hooked up the o2 senser 41 went away. the crankshaft senser i dont think is even hooked up becuase i didn't think obd 1 engines had that senser. will i hurt the engine if i drive it down to the muffler shop without it? also were is the senser located, i know is down near the crackshaft pully but is it hard to get to?
the throttle position senser is really screwing me up though. my buddy said i needed to go have it adjusted with an ome meter. is this true? if so could someone tell me how to adjustit, i have an ome meter but i do not know how to adjust it. again will this hurt the car if i drive it?
i have to drive the car to amuffler shop to have my test pipe made, it is going to be loud as hell, open header haha. gotta do it though.
thanks for the help
i was just told that Code 4:Crankshaft position senser has to do with the distributer, how do i fix the senser or replacew it?
Old Oct 16, 2002 | 01:30 PM
Perfectionist's Avatar
Default Re: engine code help (kuelerz)
The crankshaft position sensor is part of the distributor subassembly and can't be replaced by itself, as far as I know.
The throttle position sensor is checked with a voltmeter. It should read 0.45 to 0.50 volts at closed throttle, and about 5.0 volts at WOT.
shabam
Sep 13, 2007 01:43 PM
fastfu
Feb 6, 2006 09:38 AM
astig* DC2
Sep 29, 2005 10:22 AM
kuelerz
Oct 15, 2002 01:26 PM
