Engine clearances help
Good evening Honda Tech!
I have a 00 EX, D16Y8... I've been rebuilding my engine and have run into the following problem... my housing bore is measuring in at .001" under the minimum published clearance on 3 clearances and .002" below minimum published clearances on the other 2. Are there undersized bearings available out there I can use?
Any suggestions would be appreciated!!
Hondabbydriver
Jun 4, 2019 02:58 AM
Dgib1972
Oct 23, 2018 07:43 AM
EJ8_Enthusiast
25
Aug 26, 2008 09:57 AM
