engine burning oil..
Old Jun 21, 2007 | 06:48 PM
92boostedgsr's Avatar
Default engine burning oil..
i just finished a engine rebiuld on my B16
stock block/sleaves
wiseco 81.5mm pistons
peak performance rods
ge block gaurd
acl race bearings.
how long does the breakin period take, and when does it stop burning oil?
Old Jun 21, 2007 | 06:51 PM
4g hatch's Avatar
how long has it been. it really should never burn any oil if all the clearances were right. what rings did u use
Old Jun 21, 2007 | 06:57 PM
Default Re: (4g hatch)
i used the rings in the wiseco piston kit, all clearances were perfect.
it only burns on decel, like blow by. the engine has about 900km's on it.
Old Jun 21, 2007 | 07:00 PM
4g hatch's Avatar
was the seals in the head replaced and the valve guides checked. have u checked the pvc valve to see if its sucking up any oil.
Old Jun 21, 2007 | 07:03 PM
no more pcv, have a catch can and the head was fully refreshed. seals are new and fully checked. mild head work.
Old Jun 21, 2007 | 07:06 PM
4g hatch's Avatar
alot of people say those rings suck. people will have that problem then they put honda rings on there forged pistons and it goes away. oem runs the best tolerances. do a leak down test before u do any thing drastic. even if your compression #'s are good the third/oil ring could be no good
Old Jun 21, 2007 | 07:09 PM
yeah i did a compression test all cyl's were @ 205psi.
the rings suck eh, well for F*ck sakes. if i hadda know'n that i woulda done the oe rings.
Old Jun 21, 2007 | 07:10 PM
4g hatch's Avatar
those #'s are good but the oil ring could be bad. do a leak down test to see if its in the bottom end or the top end. u just never know
Old Jun 21, 2007 | 07:26 PM
yeah i'll do that. see what happen's
thanks.
Old Jun 22, 2007 | 09:20 PM
Default Re: (92boostedgsr)
funny thing.
well I was driving the car around today and it completely stopped burning oil, so i thought I'd check to see if there was any oil left in it. about 1/4 quart low, so i topped it and hasn't bunt any since. must have decided to seat,
Old Jun 22, 2007 | 10:00 PM
doood's Avatar
been there done that
how did you break it in? did you tune it?
Old Jun 22, 2007 | 10:38 PM
Default Re: (doood)
yeah ran on stock computer for about 500km's then installed the turbo ect. and went to the dyno.
Old Jun 23, 2007 | 09:47 AM
4g hatch's Avatar
good to hear.
the rook
Apr 5, 2016 02:49 PM
FireInTheHead
Nov 4, 2014 04:15 PM
joss731
Sep 15, 2010 08:50 AM
CRXSIR1
Apr 14, 2005 01:09 PM
So Cal So Boosted
Aug 5, 2004 11:41 AM
