Is it ok to mix rod bearing halves for better clearance ?
(*I am using Eagle Rods and OEM Bearings*)
Is it ok to mix the ROD bearing halves (ie. green and yellow) to achieve the correct clearance specs? I know the service manual states its ok to mix main bearing halves but they say nothing about mixing the rod bearing halves???
My number 3 and 4 rod bearings are just a liiiiiittle out of spec (the crushed plastigage strip was a little too wide) so I am thinking I probably need to change just one half to one size thinner (Yellow). Does it also matter which half goes in the top or bottom half?
Re: Is it ok to mix rod bearing halves for better clearance ?
Typically, rod bearings will say on the backing whether they are for the top or bottom of the rod.
Ummm I don't think that is correct, since they are sold individually and the part numbers are not different for a green top bearing or bottom bearing just different manufacturers and colors / thickness ...
No unless you take them to a machine shop so that they can be weighed and balanced cause each rod that comes from factory comes wieghted and balanced as a balanced assembly I mean if you take the other 3 rods and whigh them they should not be more or greater than 4 grams apart from each other if they are they must be shaved a bit at the bottom and where to shave thats where the balancing comes into play
igorka_91
13
07-05-2009 12:29 PM
