engine bearing question
Old Jan 9, 2002 | 01:57 PM
civbeater90's Avatar
Default engine bearing question
hey guys. how critical are the sizes of the engine bearings,both main and rod. i understand honda makes 3 styles for the diz6. are they all compatible or is it tight tolerance?
Old Jan 9, 2002 | 02:12 PM
SpeedracerS4's Avatar
Default Re: engine bearing question (civbeater90)
You need to use plastic gauge to measure the bearings clearance. This website will help you
Old Jan 9, 2002 | 03:22 PM
rainforest's Avatar
Default Re: engine bearing question (SpeedracerS4)
your crank and rods should say a code you should look at your manuel and see the corresponding number pattern for your motor and it will say your bearing codes. but you should plastigadge.
Old Jan 9, 2002 | 03:41 PM
civicturbo's Avatar
Both above are correct!
Old Jan 9, 2002 | 06:30 PM
Default Re: engine bearing question (civicturbo)
ok so what you guys are saying is that the bearings will have numbers stamped on them?
Old Jan 10, 2002 | 03:08 AM
Mista Bone's Avatar
D Tranny Guru
Well, you can just through in all green or yellow mains, usually what is done at the dealership.
Mine still going strong over a year later.
This is what came OUT of the motor......
Old Jan 10, 2002 | 05:26 AM
3rdShift.org's Avatar
New User
The bearings do not have numbers on them, they are market with a color coding. Some race motors are built with all red bearings (more clearance & capacity for oil), but from the factory they are varied depending on the cut of the machine tools. You will need to match the numbers provided on the bottom of the big end of the rod with the letters on the block. Arrows point toward the crank pulley. Any manual will have a chart and show you how to read the bearing codes.
Old Jan 10, 2002 | 09:22 AM
rainforest's Avatar
Default Re: engine bearing question (3rdShift.org)
yes rich rocky runs all blacks or reds allways better oil pressure. and less prone to trowing one.
Old Jan 11, 2002 | 07:44 AM
Default Re: engine bearing question (rainforest)
ok thanks for the answers.the dealer had gotten me greens so that 's what is going in.i'm sure it wil be fine.
Old Jan 12, 2002 | 11:56 PM
BuddhaSiR's Avatar
remember to plastigage. Very Important.
hybridmiklo
Jul 7, 2011 11:56 PM
TurboKneeGrow
Mar 18, 2008 07:22 PM
TurboKneeGrow
Mar 18, 2008 02:58 PM
desmone
Mar 18, 2007 04:39 PM
AzianAvenger
Jun 5, 2002 07:16 PM
