Electronic Techs: Relaying a Logic Ground, Bad Idea?
Old Nov 9, 2008 | 02:02 PM
bschulz's Avatar
Default Electronic Techs: Relaying a Logic Ground, Bad Idea?
I am entertaining the idea of using a few useless CKF wires in my main harness for a remote relay lockout type security.
My question is, if I were to relay (kill) the Logic Ground wires for the ECU could it cause any interference issues (electromagnetic etc...) with sensor inputs?
I'm probably just going to play it safe and use the power grounds.
I'm really more curious than anything...
Thanks
EDITED: That being said, I suppose I should ask if sending 12v through the shielded CKF/CKP/CYP/TDC "harness" to power the relay would cause any problems as well.
Hmm
Modified by bschulz at 3:09 PM 11/9/2008
Old Nov 11, 2008 | 07:32 AM
bschulz's Avatar
Bump for knowledge
Old Nov 11, 2008 | 09:07 AM
Relic1's Avatar
the length of ground wires matters, making them noticeably longer will likely create very strange problems.
Pumping unfiltered 12V into the shielded harness is not a good idea at all. All though I'm not 100% that the CKF is in the same shielded harness as the rest of the distributor wires.
Old Nov 11, 2008 | 09:57 AM
B18EG6's Avatar
Default Re: (Relic1)
It was in my OBD1 GSR harness
I would not relay those. Have you considered killing any grounds at the main relay?
Old Nov 12, 2008 | 12:01 PM
bschulz's Avatar
Default Re: (B18EG6)
Relic1, the extra length would only be the relay itself. Keeping it under the hood where it cannot be accessed is the plan. All the wires are shielded together so I may consider using the extra ground wires instead.
B18EG6, I wanted to keep it out of reach (hood pop is extremely relocated) and hard to bypass. Cutting ground to the ECU remotely seemed to be the best way to try it. I will be using power grounds. All I can do it try it I suppose...
Thanks guys
1badteg
Jun 11, 2011 12:46 PM
bschulz
Audio / Security / Video
Nov 13, 2008 04:51 AM
willsmysticcobra
Jun 30, 2008 06:41 PM
JDM_EK_JOE
Oct 17, 2007 02:23 PM
YoungKadafi
Welding / Fabrication
Apr 16, 2007 10:23 AM
