Electronic B18 LS tranny to Cable ef
Old Jan 31, 2014 | 03:00 PM
nateswim2002's Avatar
Default Electronic B18 LS tranny to Cable ef
Hey,
I have a 91 EF that I put an OBD2 motor in. I have already converted everything to OBD1 and car runs great. The only issue I have is my tranny is electronic and my car is cable. I need to pass BAR so I need to fix this first. Will a cable speed sensor fit and work? Or will I still throw the code since harness isnt sensing the signal? Is there a conversion available? I am stuck here at the momment.
-91 honda civic si hatch converted to OBD1
-b18b OBD2 motor converted to OBD1
-b18 LS transmission that is electronic.
-Car is for cable tranny.
-No CEL codes exept for the speed senor.
-Manual.
Thank you.
Old Feb 3, 2014 | 07:36 PM
fcm's Avatar
fcm
Old Fart
Default Re: Electronic B18 LS tranny to Cable ef
I would check in the Civic forum, maybe someone there knows of a VSS to cable adapter from one of the "engine swap" parts suppliers. 94
Old Feb 11, 2014 | 06:11 AM
94EG8's Avatar
Seagull Management
From what I recall those cars have an electronic VSS in the cluster driven by the speedo cable. Run a cable VSS and I think it should fix your issue.
Yodi71
Feb 11, 2019 12:21 PM
zenon8890
Aug 3, 2010 02:40 AM
highperboi
Jan 29, 2008 08:58 PM
F22B-EF
Mar 8, 2007 09:11 AM
red_EF9Si
May 28, 2006 08:42 PM
