electrical problem???????????????
Old Mar 8, 2004 | 07:37 AM
simplestyles's Avatar
Default electrical problem???????????????
The car will crank but the fuel pump will not run, there is no spark, the check engine light does not come on even when ignition is turned only to the run position and will not start. the fuses are all good, I changed the ecu with a good known ecu and the same thing happens. There are no check engine lights what so ever and the ground on the thermostat is good as well. can anyone help me?
Old Mar 8, 2004 | 08:12 AM
mmuller's Avatar
Mad Scientist
Default Re: electrical problem??????????????? (simplestyles)
check main relay
Old Mar 8, 2004 | 09:33 AM
92civeg's Avatar
Default Re: electrical problem??????????????? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">check main relay</TD></TR></TABLE>
Old Mar 8, 2004 | 11:23 AM
Default Re: electrical problem??????????????? (92civeg)
Thanks for the info guys I will check and let you know. if it is still good do you have any other ideas
Old Mar 8, 2004 | 02:45 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplestyles &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info guys I will check and let you know. if it is still good do you have any other ideas</TD></TR></TABLE>
Check fuses.
Old Mar 9, 2004 | 10:44 AM
Default Re: electrical problem??????????????? (Chiovnidca)
I checked the fuses it said that in the original post man
redferio
23
Sep 20, 2008 02:40 PM
pearl
Oct 25, 2005 07:27 AM
b20vtec crx
Oct 8, 2005 02:49 PM
prelude_2k1
Jul 14, 2004 08:32 AM
im_the_teacher
36
Aug 11, 2003 10:14 PM
