Dim check engine light, fuel pump wont prime, help!
Old Oct 25, 2005 | 06:51 AM
pearl's Avatar
Default Dim check engine light, fuel pump wont prime, help!
I have two classes and work today, and my car wont start
I have a 1998 Civic DX, its turbo.
All of my lights are bright (headlights, cluster lights, etc.) except my check engine light. When I have the key in the on position, i hear a ticking noise near my ECU, but the ECU isnt ticking. Is that my main relay?
My fuel pump wont prime, hence my car wont start. Anywhere to start looking?
Old Oct 25, 2005 | 07:05 AM
SOHFAST94's Avatar
Default Re: Dim check engine light, fuel pump wont prime, help! (japearl)
check the fuel pump ground near the t_stat and the main relay.
Old Oct 25, 2005 | 07:12 AM
pearl's Avatar
Default Re: Dim check engine light, fuel pump wont prime, help! (SOHFAST94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHFAST94 &raquo;</TD></TR><TR><TD CLASS="quote">check the fuel pump ground near the t_stat and the main relay.</TD></TR></TABLE>
Makes sense, I did the Tstat almost a month ago. I'll do that now and come back
Old Oct 25, 2005 | 07:17 AM
pearl's Avatar
6 pack for you my friend. thanks.
Old Oct 25, 2005 | 07:26 AM
SOHFAST94's Avatar
No problem. Happens to me all the time.
Old Oct 25, 2005 | 07:27 AM
pearl's Avatar
Well since your reading this post, would that cause my car to "bog" every once in a while? when i get on it sometimes the car falls on its face and starts back up. Would this ground being loose be the culprit?
I pm'd you this too.
JdmRex805
19
Nov 20, 2014 05:23 PM
olds1983
Honda Civic (2001 - 2005)
Dec 2, 2012 06:34 PM
Phil McConkey
Feb 25, 2007 07:42 PM
Rhythmsnewsn
Feb 9, 2007 05:17 PM
91d15bvtec
Jun 29, 2005 05:08 PM
