Electrical load detector?!?!?!?!
Old Feb 27, 2006 | 03:30 AM
ezza's Avatar
Default Electrical load detector?!?!?!?!
My ECU is throwng a CEL code 20, which is 'electrical load detector' what does this mean?
bad earth?
Old Feb 27, 2006 | 05:37 AM
Jmunk's Avatar
Time to get a new fuse box for the engine bay.
Old Feb 27, 2006 | 01:11 PM
Yip Man's Avatar
You might need to tighten up your negative ground cable more check that first.
Old Feb 27, 2006 | 02:35 PM
h22 civic's Avatar
Default Re: (Jmunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmunk &raquo;</TD></TR><TR><TD CLASS="quote">Time to get a new fuse box for the engine bay. </TD></TR></TABLE>
mite be but i would check all fuses first and check your under dash fuses as well id start with alt/sp
Old Feb 27, 2006 | 04:28 PM
tech1145's Avatar
It would really help if you have the exact DTC. It would either be a high voltage failure or a low voltage failure and the diagnosis is different for each one.
Old Mar 1, 2006 | 02:31 PM
ezza's Avatar
Default Re: (tech1145)
all i know is its a code 20
il check my earths and fuses then
Old Mar 1, 2006 | 03:21 PM
BMaDOHC's Avatar
Default Re: (ezza)
depending on vehicle but I believe there is a service bulletin on eld's for crv's. It can be purchased seperately with the parts info off of the bulletin. Some vehicles you need to replace the fuse box though.
eg6-crvtec65
Apr 4, 2007 08:31 PM
EJ8 GSR-T
Oct 23, 2004 02:06 PM
cjames235
Dec 27, 2003 06:17 AM
slowman
Jul 19, 2002 02:54 PM
Mugen Dom
Nov 15, 2001 07:19 PM
