EGR valve block off with check engine light
Old Jul 5, 2016 | 04:55 AM
Sinkic's Avatar
Default EGR valve block off with check engine light
Hello to all!
I am new here but i hope that some of you will answer to my question.
I drive Accord type R (It's swap, everything is from ATR except chassis) and few days ago I removed EGR valve and then check engine light starts so i put EGR valve back on the car but near the fuse box and connect it. There is no check engine light for 100km and then it starts again.
Now my question is : Does someone know how to remove and block off EGR valve without check engine light?
TNX.
Old Jul 5, 2016 | 02:45 PM
holmesnmanny's Avatar
Default Re: EGR valve block off with check engine light
The only way would be to get a chipped ecu and turn it off in the program options.
Old Jul 6, 2016 | 02:57 AM
Sinkic's Avatar
Yes, I know that but i hope that someone have some other solution without chipping ECU. The solution is somewhere but we must find it. Thank you.
Old Jul 6, 2016 | 09:32 AM
tony_2018's Avatar
Fish Twig
Whats the actual code.
Old Jul 7, 2016 | 03:03 AM
There is no other solution, a chipped ecu is the ONLY way to turn off the egr or you can just leave it on as it serves a good purpose.
Old Jul 7, 2016 | 04:57 AM
Sinkic's Avatar
The actual code is 8 or maybe 88, i am not sure because always blink 8 8 8 8 8 8 8 8 8 8 8.
Or maybe it's 80, that mean Exhaust Gas Recirculation insufficient flow detected.
If it is 8 TDC - top dead centre sensor.
I think that is 80 and that's normal because of EGR.
Old Jul 8, 2016 | 06:47 AM
tony_2018's Avatar
Fish Twig
Take a video of the CEL blinking.
Old Jul 8, 2016 | 02:02 PM
Sinkic's Avatar
I can't upload because it's too long and too big.
Old Jul 8, 2016 | 02:24 PM
Sinkic's Avatar
Here is a link of video.
https://jumbo.iskon.hr/dl/edb0b931-3...4-54f70abc9726
Old Jul 8, 2016 | 04:35 PM
v4lu3s's Avatar
RTFM
there is no way around since not only does it check lift it also checks flow for the EGR. Fuel mapping and ignition mapping are based on the egr flow as well. the egr allows for a leaner mixture that also burns slightly cooler allowing for better emissions and fuel economy at part throttle. it remains closed under wide open throttle.
MRsol
Engine Management and Tuning
Dec 5, 2009 03:45 PM
angryk
Honda Civic (2001 - 2005)
Dec 28, 2007 11:53 AM
sergei_sh
Mar 13, 2006 06:19 PM
JDMej1Civic
Mar 15, 2005 05:28 PM
GVERMILLION
Jan 19, 2003 01:39 PM
