EG k20 swap issues
Old Jan 23, 2012 | 08:54 AM
GSi-R's Avatar
Default EG k20 swap issues
hey guys, i have these problems with my swap
its a EG jdm k20a swap with stock ep3r ecu
-the car is running really really rich, ive got the o2 sensors and airtemp sensors connected,
-the fuel pump doesnt stop priming
-the car wont start straight away i have to wait a bit before cranking
and if i turn off the car and then try to start it , it hesistates a lot
before starting again and have to like accellerate then it will start and i
can smell fuel.
-there is **** load of heat coming from the engine bay into my cabin
i know k-pro could fix these issues but im currently in a lot of debt atm
and wont be planning on it for sometime, but if anyone can help me out
would be great thanks guys
heres some info,
jdm k20a swap, hr conversion harness, k-tuned fuel setup, 4-1 headers to straightpipe, prd ecu,
Old Jan 23, 2012 | 09:45 PM
GSi-R's Avatar
Default Re: EG k20 swap issues
bump
Old Jan 24, 2012 | 07:40 AM
grumblemarc's Avatar
The Grumpiest
Originally Posted by 2fastek
Go to k20aorg and search for k20tuned, a guy named Dale. He sells the ecu you need to run the kswap without kpro for 330 shipped. it has the immobilizer removed as well as secondary o2 sensor nd some other sensors. You can upgrade to KPRO later since the ecu is already pre prepped.
If you don't have the cash for that then it sounds like you're screwed.
http://www.k20a.org/forum/
tommychong
Mar 14, 2018 11:01 AM
nuginu
Aug 3, 2013 02:01 PM
GSi-R
K Series
Jan 25, 2012 07:09 AM
92EGK20
Sep 17, 2007 10:44 PM
