k20 swap plz help lol
Old Dec 4, 2011 | 05:16 PM
sohc-monster's Avatar
Default k20 swap plz help lol
Ok I'm swapping my tired d16z6 for a fresh k20 I have almost everything I need except ecu and header. Where I need help is I cannot afford kpro yet but I'm ready to get this beast on the road what can I do I got the k20a3 out of a base rsx 5speed tranny and am not sure if I can use the type s ecu or not b/c that is all I have found on ebay is ecus for 6 speed trannys please help the ecu code would help me tremendously incase I have to buy from honda thanks
Old Dec 5, 2011 | 12:26 PM
Default Re: k20 swap plz help lol
Nice over 100 views and no help maybe someone can help me out
Old Dec 5, 2011 | 01:03 PM
BMAK10's Avatar
i think u need to use the 5 speed ecu unless theres a way to convert it..u might want to try to look into k20a.org thats where i got all my info about my k swap
Old Dec 5, 2011 | 02:53 PM
thank you
Old Dec 5, 2011 | 10:07 PM
Jimster480's Avatar
idk if you can actually do it without kpro. I mean i dont know much about K swaps but i didnt think that it was possible. Since K's are drive by wire and stuff, and those things have to be converted.
Old Dec 6, 2011 | 05:24 AM
2fastek's Avatar
Go to k20aorg and search for k20tuned, a guy named Dale. He sells the ecu you need to run the kswap without kpro for 330 shipped. it has the immobilizer removed as well as secondary o2 sensor nd some other sensors. You can upgrade to KPRO later since the ecu is already pre prepped.
Old Dec 6, 2011 | 06:00 AM
BoostdKseries's Avatar
you can do what the guy above said.. i believe its called a doc kswap ecu. also, you can buy the 5 speed ecu and go to k tuned and get the immoblizer bypass and wire it into the harness near the ecu and it will run.. you cant run the 6 speed ecu with the a3 because from the factory the type s ecu is tuned for that motor. not the a3 motor. also, k series are a money pit. good luck and hope you get that thing running!
Old Dec 6, 2011 | 06:06 AM
unless you had kpro, then obviously you can run the type s ecu.
Old Dec 6, 2011 | 10:48 AM
DawgC2's Avatar
Do anyone know if you can get the immoblizer working with the swap??
Old Dec 8, 2011 | 05:14 AM
Thanks for all the help
Old Dec 8, 2011 | 05:38 AM
grumblemarc's Avatar
The Grumpiest
K20a.org. Don't know why you're messing around over here.
DXK Eg
Feb 18, 2012 03:51 PM
dliz88
Apr 22, 2009 04:58 PM
gregv
Jun 17, 2002 01:15 PM
