K Swap Experts please chime in. K20A2 Swap into Eg hatchback
Hey guys what’s up. My name is Lance and I am 24 years of age from Toronto, Ontario. I have been building Honda civics for a little while now. I recently acquired a 92 Si hatchback from my uncle which I couldn’t turn down so I have been piecing together a K swap for the car. I have a few questions that I cannot find the answers to online. I plan on using a k20a2 full swap with engine harness but with a Jdm K20A PRC ecu. Yes I understand I’m better off with a K pro but that is the plan down the road. This k swap is on a very very very tight budget. I will be pairing the stock harness with a k tuned conversion harness. My main question is what will I have to do electronically to make the PRC ecu work with the k20a2 swap the correct way as in no check engine light and will I have to have a primary and secondary 02 sensors if I do need a secondary 02 sensor which usually plugs into the floor harness how shall I go about doing that. My other question is what fuel kit do I need to run the stock k20a2 fuel rail? I hope to hear back from the OG’s that can give me some help. Thank you in advance.
BlackAlbumKoupe
12-07-2009 09:44 AM
