Installing SiR II B16 into 95 CX EG
Installing SiR II B16 into 95 CX EG/ WIRING QUESTION
As far as the wiring goes. I was wondering if the only wires I would have to add to the stock CX harness would be for the VTEC? I was going to use the JDM harnesses VTEC wires and rewire them into the CX harness. Is this right? Thanks for any help
Modified by dkboyny11 at 11:16 AM 4/15/2007
Re: Installing SiR II B16 into 95 CX EG/ WIRING QUESTION (BlueIntegraBoy)
I'm using the cars stock harness so the plugs should work out for me. I'm only using the RHD harness for the VTEC solenoid, Knock sensor, and pressure sensor. Those wires I'm going to re-wire into the stock CX harness and extend them to the ECU.
ok, Then the O2 sensor is the other one I was thinking of. Thanks for your help. Just add wires for the 4wire O2 instead of the single it had before? I have the O2 sensor that came with the motor.
