EF vs. DA ECUs
Old Jun 20, 2002 | 06:03 PM
Quick 200k Mile Motor's Avatar
Default EF vs. DA ECUs
I was wondering if the female connection sides are the same…
On a OBD0 88-91’ USDM Civic/Crx Sohc ECU
And on a OBD0 90-91’ USDM Integra ECU
If they are the same, then it should be possible to convert a 90-91’ Integra to OBD1.
So far I havent found anyone that has done the conversion for a 90-91’ Integra. I remember reading someone sells the harnesses for the EF conversion. Would that harness do any good for a DA? The goal is to run a P28, P30, or P72 (whatever is less of a pain in a OBD0 DA).
Old Jun 21, 2002 | 01:49 AM
dlric's Avatar
Default Re: EF vs. DA ECUs (Quick 200k Mile Motor)
by female side do you mean the wire harness side that plugs into the ecu? they are the same, yes. a 90-91 ecu will plug right into a 88-91 wiring harness.
Old Jun 23, 2002 | 02:33 AM
Giuseppe's Avatar
yes what u stated is 100% right, you can make your 90-91 integra
an OBD1 car. you need to get an adapter harness
and go from non OBD to OBD1. blown90hatch on this board makes them...
and then u need an OBD1 ECU....hth oh u need a set of saturated injectors too,..
good luck!
SpadeZ56
Engine Management and Tuning
Jun 22, 2014 04:56 AM
BIGef
Aug 22, 2012 06:31 AM
IntegraGuy16
Jun 24, 2006 05:50 AM
DvSiR
Jun 4, 2003 03:33 PM
Aphrodavid
May 11, 2003 04:41 PM
