OBD0 To OBD1 Conversion help....LS/Vtec in EF
Old Jun 22, 2006 | 09:11 PM
IntegraGuy16's Avatar
Default OBD0 To OBD1 Conversion help....LS/Vtec in EF
I have a 90 EF hatch that i'm putting a ls/vtec into. The head is OBD0 Jdm B16 head on a 95 integra LS block. I want to convert to obd1 because i want to run a chipped ecu but i'm a little confused. I have to buy the obd0-1 ecu conversion harness, and then the obd0-1 distributer plug correct? I already have the obd1 ecu. Ok well my question is, do the wires that run off the harness go to the distributer plug? Also the harness i would be using is the stock dx harness. I guess i'm just confused because theres two plugs off the distributer and only like 7 or so wires that come off the ecu harness. If anyone could clear this up for me I would appreciate it!. Sorry if this makes no sense, its early in the morning and i'm tired
Old Jun 23, 2006 | 07:53 AM
Default Re: OBD0 To OBD1 Conversion help....LS/Vtec in EF (IntegraGuy16)
Morning Bump
Old Jun 23, 2006 | 06:09 PM
BlueCrxNC's Avatar
If you are using your DX harness you have to convert to MPFI (multi-point fuel injection) from the old DPFI (dual-point). Do a quick archive search on DPFI to MPFI and you'll get flooded with info.
Old Jun 23, 2006 | 08:23 PM
Default Re: (BlueCrxNC)
Yes I know, it's already converted to 4 injectors.
Old Jun 24, 2006 | 04:44 AM
BlueCrxNC's Avatar
Default Re: (IntegraGuy16)
This help with the distributor?
Old Jun 24, 2006 | 05:50 AM
yes, thanks very much
t-town_ep
Nov 19, 2012 12:54 AM
DA john
Nov 10, 2011 10:36 AM
88zchatch
15
Mar 20, 2009 12:06 PM
FAST AS
Jan 5, 2004 01:24 AM
88da3
Nov 13, 2003 01:12 PM
