ECU testing?
Does anyone know of a way to test an ECU? I bought a car without a motor but I am swapping the motor and want to sell the old ECU from the car but I don't have anyway of testing it on the car as of now..
The car is a 93 Del Sol
so its xxxxx-p28-axx last 2 numbers has a 5 in it somewhere?
im not sure about running auto ecus in manual car, auto ecu codes?
ideally it would need to be test in a auto sohc v d16z6, like eg auto ex
maybe someone could chip in on running auto ecu's in manual cars, i mean there is always converting it to manual but idk if ud want to do that
so basically if it gets plugged into a d16z6 motor and it actually starts and doesn't throw any codes it should be good? sorry i'm not very experienced on the technical side of ECU's and all... haha anything else mechanically I am fine on but electronics are another ballgame...
if it starts, it will throw the auto sensor code. if thats the only codes then it should be no problem converted to manual. the only thing you might not know is if the automatic circuitry works. but most people who would buy it will convert it to manual anyways
Fook_me_honda
Jan 9, 2008 11:58 PM
