ECU testing?
Old Aug 28, 2011 | 08:55 PM
bendrums87's Avatar
Default ECU testing?
Does anyone know of a way to test an ECU? I bought a car without a motor but I am swapping the motor and want to sell the old ECU from the car but I don't have anyway of testing it on the car as of now..
The car is a 93 Del Sol
Old Aug 28, 2011 | 09:22 PM
civickiller's Avatar
Default Re: ECU testing?
any friends car u can test it on ?
Old Aug 28, 2011 | 09:40 PM
bendrums87's Avatar
didn't think about that but I don't know anyone with a del sol
Old Aug 28, 2011 | 10:28 PM
what ecu is it?
Old Aug 28, 2011 | 10:52 PM
bendrums87's Avatar
It was the stock ecu in a 93 del sol si auto... other than that I don't know off hand or what markings on it indicate what ecu it is
Old Aug 28, 2011 | 11:14 PM
mouab18c1's Avatar
What do you need to test the ecu for?
Old Aug 28, 2011 | 11:44 PM
bendrums87's Avatar
I just want to see if there's anything wrong with it... if it's good then I was going to sell it
Old Aug 29, 2011 | 04:15 AM
so its xxxxx-p28-axx last 2 numbers has a 5 in it somewhere?
im not sure about running auto ecus in manual car, auto ecu codes?
ideally it would need to be test in a auto sohc v d16z6, like eg auto ex
maybe someone could chip in on running auto ecu's in manual cars, i mean there is always converting it to manual but idk if ud want to do that
Old Aug 29, 2011 | 10:08 AM
mouab18c1's Avatar
It's fine testing out an auto ecu in a manual car. You'll just throw the CEL for the auto something. Won't hurt anything.
Old Aug 29, 2011 | 08:20 PM
bendrums87's Avatar
so basically if it gets plugged into a d16z6 motor and it actually starts and doesn't throw any codes it should be good? sorry i'm not very experienced on the technical side of ECU's and all... haha anything else mechanically I am fine on but electronics are another ballgame...
Old Aug 29, 2011 | 08:39 PM
if it starts, it will throw the auto sensor code. if thats the only codes then it should be no problem converted to manual. the only thing you might not know is if the automatic circuitry works. but most people who would buy it will convert it to manual anyways
Old Aug 29, 2011 | 09:55 PM
mouab18c1's Avatar
Throwing a CEL will be normal. As long as it's not a solid CEL then the ecu is working properly.
Old Aug 30, 2011 | 07:45 PM
bendrums87's Avatar
ok thanks for all the input I will start doing some digging then
suspirocrx
Mar 8, 2010 03:13 PM
mrspeedy69
Apr 18, 2009 02:47 PM
Fook_me_honda
Jan 9, 2008 11:58 PM
Orangedragone
Nov 4, 2004 09:09 PM
ek_will
May 4, 2003 07:24 PM
