doing a head swap
Old Mar 26, 2005 | 11:42 AM
DarkBB4's Avatar
Default doing a head swap
swapping a type s head on to my jdm h22. The head is only partially put together and is pretty dirty...what are the necessary steps to cleaning the head? Can i just use degreaser or break cleaner? About how long of a job is the entire swap? Expected HP gains?
Old Mar 27, 2005 | 06:29 AM
DarkBB4's Avatar
Default Re: doing a head swap (DarkBB4)
up
Old Mar 27, 2005 | 06:59 AM
jamey220's Avatar
what exactly is in the head valves, springs, retainers, cams, or are u just trying to make it look new?
Old Mar 27, 2005 | 07:31 AM
DarkBB4's Avatar
valves springs retainers, mild port and polish+port and polish directly from honda, throttle body, intake manifold
Old Mar 27, 2005 | 09:47 AM
projectTeG's Avatar
water??????....J/K, i used carb cleaner on my head when i had all the seals off, but i dont know if itll damage the seals..
Old Mar 27, 2005 | 05:36 PM
PrettyLude's Avatar
you want that head to be really clean, hot tank it
Old Mar 27, 2005 | 05:42 PM
projectTeG's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">you want that head to be really clean, hot tank it</TD></TR></TABLE>
won't that mess the seals up???? thats why i had to replace my valve seal because previous owner had a shop relace a burnt valve and the hotanked the head and fried the seals
Old Mar 27, 2005 | 06:20 PM
Dragline's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
won't that mess the seals up???? that's why i had to replace my valve seal because previous owner had a shop relace a burnt valve and the hotanked the head and fried the seals</TD></TR></TABLE>
If its that dirt maybe you should take it to a machine shop and have it disassembled and check out anyway
SVOboy
19
Jun 22, 2006 05:30 PM
EFMAN
13
Apr 10, 2006 07:49 PM
si0385.
Feb 13, 2006 07:40 PM
^AnDre^
Dec 1, 2004 10:51 AM
accordfreak
Dec 10, 2002 03:46 PM
