Does winter climates really affect gas mileage THAT much?
Old Feb 1, 2003 | 12:22 AM
MeanGreenEG9's Avatar
Default Does winter climates really affect gas mileage THAT much?
I've been avg about 20-22mpg last couple of months. Now I live on the eastcoast and lately its been cold as sheeiit around here.. probably around 20-40 degrees everyday. I heard cold weather hurts gas mileage a lot but I should be getting more like 26-28mpg according to what other peeps with b16As are telling me... I do mostly highway driving and I shift before 4k at all gears but I'll run it to 8k maybe once or twice per day.. I'm just trying to see if this is normal because of cold weather or maybe I should check somthing else?
Old Feb 1, 2003 | 12:27 AM
.(Lazarus).'s Avatar
Default Re: Does winter climates really affect gas mileage THAT much? (B16aEJ)
Do you have a chipped p28? Those usually give bad mpg. Mine gets about the same miliage you're talking about (20-22mpg) with that setup.
Old Feb 1, 2003 | 04:31 AM
97civicdx's Avatar
During the winter months, gas stations use oxygenated fuel. This could be a cause to the bad gas mileage. Another thing is when you first start up the car, it goes into its high idle, another probable cause.
Old Feb 1, 2003 | 06:17 AM
speedymon's Avatar
Default Re: Does winter climates really affect gas mileage THAT much? (97civicdx)
Never heard of that! I live in DC too. Do they do that here?
http://www.energy.ca.gov/gasoline/ty..._gasoline.html
[Modified by speedymon, 10:21 AM 2/1/2003]
Old Feb 1, 2003 | 06:46 AM
CivSOHC's Avatar
Default Re: Does winter climates really affect gas mileage THAT much? (speedymon)
i commute back and forth to school every day, and usually i get aroudn 35-37 mpg when its warmer out. Im in PA its been cold as **** lately and im barely over 30 mpg lately and i haven't changed my driving style at all. WINTER SUCKS
later
Old Feb 1, 2003 | 07:04 AM
delslow94's Avatar
yea thats sunoco's "easy start" formula. they use oxygenated fuel in the winter
Old Feb 1, 2003 | 09:19 AM
jweller's Avatar
In MD they used to use oxygenated gas in the winter months, several years ago they switched to oxygenated year round
Old Feb 1, 2003 | 11:35 AM
speedymon's Avatar
Default Re: Does winter climates really affect gas mileage THAT much? (jweller)
How can you tell if you're buying oxygenated or not? Does that stuff wear out your O2 sensor faster?
Old Feb 1, 2003 | 07:57 PM
CereaLand's Avatar
Does the O2 sensor affect gas mileage that much?
Old Feb 1, 2003 | 08:04 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
https://honda-tech.com/zerothread?id=397320
djdownfawl
Honda Civic (2001 - 2005)
13
Mar 23, 2008 07:57 PM
mahatma
Nov 27, 2006 08:14 AM
Propulsion
Feb 21, 2004 12:20 PM
E Swift
Dec 20, 2003 04:37 PM
CC2
Nov 4, 2002 04:02 PM
