does check engine light take away power
Old Nov 18, 2002 | 01:18 PM
TruePlayaz114's Avatar
Default does check engine light take away power
I was just curious cause i hear a lot of people say that when a check engine light is on the car only runs at about 75%. Is this true?
Old Nov 18, 2002 | 01:24 PM
dfoxengr's Avatar
Default Re: does check engine light take away power (TruePlayaz114)
lol, probly cause theres a problem, lol
Old Nov 18, 2002 | 01:45 PM
Cynical 1's Avatar
Default Re: does check engine light take away power (hybridvteceg)
It only takes away power after your engine blows because something was wrong.
Old Nov 18, 2002 | 02:01 PM
Perfectionist's Avatar
If the CEL comes on and goes away, it's an intermittent fault and in most cases will not affect performance. However, the cause should be investigated and corrected.
If the CEL is on constantly, the engine is running in open loop or 'limp' mode. Basically, the ECU relies on a base fuel/timing/ect. map and does not correct for ambient operating conditions. In this mode, as 'limp' implies, you are not running at optimum fuel efficieny or power. I don't know if you can quantify the decrease to a simple 75% though. A lot of factors are involved.
Old Nov 18, 2002 | 02:23 PM
keebler65's Avatar
Default Re: does check engine light take away power (Perfectionist)
also it usually lowers your rev limiter and i believe disables vtec if i am not mistaken
Old Nov 18, 2002 | 02:29 PM
CivicEx95's Avatar
Default Re: does check engine light take away power (keebler65)
the ignorance is strong in this thread
depends on what the CEL code is. You're car won't be able to get data from that sensor and therefore unable to use that input to change the injector pulse width.
Old Nov 18, 2002 | 03:38 PM
dfoxengr's Avatar
Default Re: does check engine light take away power (CivicEx95)
there was a post recently about codes, all of them. just jump the check terminals near the ECU, and get the code. unless its OBDII and u have access to a computer checker thing. or even if u have acces to a crucially expensive OBDI computer with the right connector plugs.
Old Nov 18, 2002 | 07:45 PM
so basically it does affect performance. Not always but usually. Well i know someone that has a 2001 Prelude. It's got the usual i/h/e and a V-AFC. Sometimes the check engine light comes on and sometimes it doesen't. What's up with that
Old Nov 18, 2002 | 08:08 PM
1 2 NV's Avatar
OBD2 cars have the service jumper connector too.
Old Nov 19, 2002 | 03:51 PM
dfoxengr's Avatar
Default Re: does check engine light take away power (hondaatwsu)
correct, didnt say they didnt now did I, but the code scanner is easier.
Old Nov 19, 2002 | 03:52 PM
And thank you for sharing yours.
Not all sensors have an effect on the fuel trim function.
Old Nov 19, 2002 | 06:05 PM
tinkerbell's Avatar
OMG!
you are ALL wrong!
the CEL is 1/4w bulb MAX!
it would draw less than 100mA when it is on.
it would take away virtually no power!!!
hth,
t..
find out the code & get back to us (pls start a new thread ), or take it to the dealer and get it looked at...
[Modified by tinkerbell, 1:06 PM 11/20/2002]
Old Nov 19, 2002 | 06:42 PM
baonest1's Avatar
haha man that made my day
Old Nov 20, 2002 | 09:01 AM
Default Re: does check engine light take away power (baonest)
ok here's the situation. Every since my friend got the V-AFC installed and tuned, everynow and then the check engine light comes on. But the mechanic said this would happen. Something because it's OBD2 and not OBD1. So he said when ever it comes on just unplug the negative from the battery and it will go away. This does work but it comes back everynow and then. But then we raced and his light was on and we were just curious if that takes away power or anything.
Old Nov 20, 2002 | 09:15 AM
Desslok's Avatar
no
Old Nov 20, 2002 | 09:21 AM
Default Re: does check engine light take away power (sp)
good answer
hondaswap
Engine Management and Tuning
18
Apr 28, 2009 10:17 AM
Bambinoh
Apr 6, 2008 05:14 AM
95DX_D15B
May 9, 2006 11:29 AM
Hatchback of Notre Dame
10
Mar 27, 2006 10:36 PM
rad_thundercat
Apr 21, 2004 08:20 PM
