Do you really this mount/bracket
Old Aug 18, 2002 | 03:20 PM
Boost2NA's Avatar
Default Do you really this mount/bracket
On my 99 civic it has a bracket that the a/c compressor used to be mounted to. since the a/c compressor is now gone is there really any use for that bracket. Its a pretty big bracket and would save a few pounds(every little bit helps). Thanks again everyone.
Old Aug 18, 2002 | 03:26 PM
boomslang's Avatar
Default Re: Do you really this mount/bracket (Boosted99Si)
Uh, yeah. It's also a motor mount.
Old Aug 18, 2002 | 06:53 PM
Brian_92GSR's Avatar
New User
All the bracket does is mount the AC, so no it won't be needed anymore.
Old Aug 18, 2002 | 07:12 PM
boomslang's Avatar
Default Re: Do you really this mount/bracket (Brian_92GSR)
Huh? It holds the motor in the car too. You have to have it unless you want to drive around with your engine crooked and boucing off the pavement. Yes, the AC compressor bolts to it. But it's main purpose is that of an engine mount.
Old Aug 18, 2002 | 10:00 PM
lsvtec94's Avatar
Default Re: Do you really this mount/bracket (Inlinefour)
i ran without this bracket in my hatch with a b16 in it for awhile and the motor didnt move.
Old Aug 18, 2002 | 10:28 PM
B18C-EJ1
Guest
Posts: n/a
You're on crack. It's also the mount for the drivers lower torque bushing that attaches the engine to the frame.
If it wasn't necessary, do you think the factory would have included it?
Old Aug 18, 2002 | 10:44 PM
lsvtec94's Avatar
Default Re: Do you really this mount/bracket (B18C-EJ1)
this bracket isnt used in crx's.
Old Aug 18, 2002 | 11:13 PM
boostaholic's Avatar
Default Re: Do you really this mount/bracket (lsvtec94)
It's a motor mount, use it. Lose the weight elsewhere, don't shed a few pounds by removing a mount that holds your motor to the rest of the car.
Old Aug 19, 2002 | 02:47 AM
ninesecrx's Avatar
Default Re: Do you really this mount/bracket (boostaholic)
you can chop the mount in half if you want to save weight...just cut it right along the line where the 2 bolts near the outside go. That way you still have 2 bolts into your block and your still useing the mount. By the way, its not used on a crx because they run a front trany mount.
Old Aug 19, 2002 | 02:56 AM
Boost2NA's Avatar
Default Re: Do you really this mount/bracket (ninesecrx)
thanks guys i think after reading these replys the bracket will go back on. Thanks
XkjeldorX
Jun 21, 2006 01:49 PM
SLeePeR012
Feb 21, 2004 05:59 PM
SLeePeR012
Feb 21, 2004 04:43 PM
ECKOTYPER
Dec 15, 2003 02:25 PM
ill phil
13
Sep 24, 2003 12:56 PM
