DIY clutch install
Old Jan 9, 2003 | 02:01 PM
-Whitey-'s Avatar
Default DIY clutch install
im gonna hopefully install a exedy organic race clutch in the b16 this weekend and i was wondering if anyone has any tips or pointers that would make it easier..also im looking for some online instructions if anyone knows of any..so far ive done all the work to my car and 2 of my friends cars so iknow i can do it its just the fact ive never done it before that worries me
i made a thread in the eg and itr forum as well...thanks
Old Jan 9, 2003 | 02:47 PM
-Whitey-'s Avatar
Default Re: DIY clutch install (one-syk)
useless forum
Old Jan 9, 2003 | 02:48 PM
lazy bum shaughn's Avatar
Get yourself a Helms book.
Old Jan 9, 2003 | 03:38 PM
TypeSH's Avatar
useless forum
... maybe you should give the forum guys a lil more htan 45 mins before calling them useless . or dont be so useless and try a search. The topic has been covered before.
Old Jan 9, 2003 | 05:31 PM
-Whitey-'s Avatar
Default Re: DIY clutch install (TypeSH)
i said this is a useless forum because it took 5 minutes for the itr and eg forum to reply and this is the tech forum and it always takes forever to get an answer we shouldnt even have this forum its useless
Old Jan 9, 2003 | 05:55 PM
tinkerbell's Avatar
Default Re: DIY clutch install (One-Panda)
hooray for the multiple cross-post!
good luck
t..
Old Jan 9, 2003 | 07:14 PM
integra6650's Avatar
cspeed
Old Jan 9, 2003 | 07:44 PM
Chrislow's Avatar
Rip the axle out (undo the control arm, **** that castle nut). Undo the tranny mount and put a jack under the oil pan. Undo all the 17's you can find that look like they are holding the tranny on and then undo the lower starter bolt cause that bastard is holding the tranny on too. Give her a shake and take it out. Pressure plate off, clutch falls out, resurface flywheel if you want, clutch back on, aline with a 2 dollar alignment tool from autozone or wherever, pressure plate on, tranny on. Easy stuff.
Old Jan 10, 2003 | 01:25 AM
Westrock2000's Avatar
Default Re: DIY clutch install (Chrislow)
Ahh yes, you learn the 10, 12, 14, 17, and 19 by heart eventually
BTW I went to O'Reilly's to get an alingment tool and they had like fords, GM's and Opels....Opels?!?!? in Texas?!?!
Pepboys only had a universal metric one with various shanks, but it worked.
Old Jan 10, 2003 | 10:04 AM
Chrislow's Avatar
Default Re: DIY clutch install (Westrock2000)
Yeah I didn't even know they were that cheap, I just lined it up by eye and a screw driver when I did mine. I was working on my buddies dsm the other day and he had one and told me they were only like 2 bucks.
Old Jan 10, 2003 | 11:12 AM
tilt's Avatar
https://honda-tech.com/zerothread?id=375643
Old Jan 10, 2003 | 03:03 PM
-Whitey-'s Avatar
Default Re: DIY clutch install (tilt)
my clutch came with a alignment tool
i have everything done im just waiting for a friend to arrive (in about 2 hours) to help with the trans removal
i got everything else done in about 60 minutes
i know 5mm-23mm by heart just by looking at the head of a bolt(thats what happens when you work in a body shop)
Ricey McRicerton
28
Nov 23, 2004 04:56 AM
BauleyCivic
59
Aug 15, 2004 09:53 PM
chronodyne28
Jul 4, 2004 03:12 PM
