distributor rattles...
Old Oct 27, 2007 | 08:34 AM
DAslammed's Avatar
Default distributor rattles...
I just bought a 93 integra, the distributor rattles at 30plus mph, i notice that its not an oem one also.... opened it and tighten all bolts, rotor... all looks new... but same problem... what should i do? find an oem replacement? is it a wire problem? or can i fix it?
add: doesn't rattle at neutral when reving
Old Oct 27, 2007 | 10:11 AM
bigkvn77's Avatar
Default Re: distributor rattles... (DAslammed)
Are you sure the noise is comming from the dizzy. Usually the noise would arise with rpm, if its comming from the dizzy. The dizzy doesn't receive differant loads from vehicle speed vs rpm.
You may want to reinspect the sound and verify where else it might be comming from. Also what kind of noise are you hearing. May beable to guide you in the right direction.
Old Oct 28, 2007 | 08:30 PM
DAslammed's Avatar
Default Re: distributor rattles... (bigkvn77)
sometimes it rattles while at a complete stop... i pop the hood and sure the noise was comming from the dizzy, sounds like rotor clicking, tightened all bolts and rotor, still same problem any help??? or should i look around for a oem dizzy?
Old Oct 29, 2007 | 12:18 AM
vteczone's Avatar
may be LMA..or some parts of the rotating assembly.. just cex by listening carefully where its coming from.
Old Oct 29, 2007 | 05:08 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (vteczone)
if you hold the dizzy does it stop? are you for sure its comming from inside? find a donor one and test. (borrow from a friend)
Old Oct 29, 2007 | 05:19 AM
Duane_in_Japan's Avatar
Default Re: (B16B_coupe)
Everyone is asking if its your dizzy, of course you should use a stethoscope to be sure but I am suprised no one yet told you that YES, this could happen, half way down the shaft inside the dizzy is a bearing, it goes bad, and you hear the rotor hitting the **** inside the dizzy that go to each spark plug wire.
Go to the dealer (ask for a discount) and buy a dizzy sub assy and transfer over your coil and ignitor, if you have that type. Buy a new cap and rotor from your discount store. Let me back up a second, if its hitting the **** inside then just pull the cap and look at them, if you have cut marks on the ****, or metal colored dust or rust looking dust all on the inside of you cap, then its a bad bearing and follow instructions above, seen it many times, takes real skill to change this bearing and inner oil seal, not really worth the trouble for some.
Did we ask if you were sure if the noise was from the dizzy.
Old Oct 29, 2007 | 06:00 AM
DAslammed's Avatar
Default Re: (Duane_in_Japan)
thanks for all the help guys, taking out a friends obd2 dizzy today for a test, but mine is an obd1 dizzy.... are those 2 the same?
Old Oct 29, 2007 | 06:13 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (DAslammed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAslammed &raquo;</TD></TR><TR><TD CLASS="quote"> thanks for all the help guys, taking out a friends obd2 dizzy today for a test, but mine is an obd1 dizzy.... are those 2 the same?</TD></TR></TABLE>
no they are not the same, and yes your bearing could be shot in it as he said above and it would shake around... but we dont want you to replace something that isnt for sure the rattle you know.
Old Oct 30, 2007 | 06:44 PM
eg6_itb's Avatar
Check the t-belt if thats loose that would cause the rotor to move around in the distro.....good luck!!
Old Oct 31, 2007 | 06:55 AM
DAslammed's Avatar
Default Re: distributor rattles... (eg6_itb)
lose timing belt? checked and rotor is not lose... anyone just sell me an obd1 dizzy
Old Oct 31, 2007 | 08:38 AM
CRX T-Si's Avatar
The distributor will make some ticking noise which is normal as the electrical current passes thru the contacts.
If the Bearing in the Dizzy is bad then you will see oil coming out of your dizzy cap on the bottom. And if it's really bad then your car won't start because the dizzy contacts are very close if it has too much play then it will come in contact with the sensors and that will kill the dizzy entirely.
unless you use OEM replacement parts for the cap and rotor there clearances will be slightly different and the more clearance it has the louder the ticking.
Hope this helps
Old Oct 31, 2007 | 07:49 PM
Default Re: (CRX T-Si)
There is truth in what you are saying but if the rotor is hitting the contacts for the spark plug wires, the car will still run, there just wont be any air gap between the rotor and the contacts, better for the spark strength (ever so slightly), bad for cap and rotor and entire dizzy.
Old Nov 1, 2007 | 09:10 AM
DAslammed's Avatar
Are the gsr obd1 dizzy same as obd1 LS dizzy? they look the same w/ same harness, ???
Old Nov 7, 2007 | 08:02 AM
DAslammed's Avatar
can i just grease up the bearing assembly?
Old Nov 7, 2007 | 12:50 PM
CRX T-Si's Avatar
The Dizzy bearing is a sealing unit.
If you grease it then you will mess it up.
Old Nov 7, 2007 | 02:51 PM
eg6_itb's Avatar
Old Nov 8, 2007 | 03:23 AM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAslammed &raquo;</TD></TR><TR><TD CLASS="quote">Are the gsr obd1 dizzy same as obd1 LS dizzy? they look the same w/ same harness, ???</TD></TR></TABLE>
no one is vtec the other isnt.. and you cant grease it.. just buy a new one of test one with a friends
Old Nov 9, 2007 | 07:04 AM
DAslammed's Avatar
this dizzy thing is making me dizzy bought an obd1 ls diz from a 95 teggy, same plugs different bolt pattern i think only 92, 93's will fit mine, holla if you have a spare
Old Nov 9, 2007 | 08:11 AM
CRX T-Si's Avatar
Just chop one of the Legs off man and it will fit.
Lots of people does it.
Tasp72
Feb 16, 2016 04:50 PM
allmotaeg6
10
Apr 12, 2004 11:56 AM
Spoonin
Jun 28, 2003 01:47 AM
Xlerate9
Feb 27, 2003 08:31 AM
AK94GSR
Feb 24, 2003 11:39 AM
