Distributor problems
Old Feb 3, 2003 | 04:29 PM
FitCRX's Avatar
Default Distributor problems
I have had some problems with my distributor in the last week, it was replaced with a new one, still having a problem. It is loseing power, like I have a bad connection, one minute it will spark, next time its weak, and some times no spark at all(which makes for an exciting ride). The distributor is new so I don't think it is the modual or coil. It could be something to do with the ECU, but I believe the wires are in bad shape and that is whats causeing the problem.
I'm taking it tomorrow to a Auto Electrican to see what he says, but would a MSD ingnition fix my problem?
If so what to use?
6A ?
6AL(really don't think I need a limiter but keeping options open) ?
cap ?
blaster ?
Old Feb 3, 2003 | 05:49 PM
VTECVillain's Avatar
Default Re: Distributor problems (FitCRX)
An aftermarket ignition isn't the answer to your problem(s). I would find out what is causing the problem and repair that part. Poor ground, faulty ignition coil, fouled spark plugs, bad plug wires - lots of possibilities.
Old Feb 3, 2003 | 06:39 PM
FitCRX's Avatar
Default Re: Distributor problems (VTECVillain)
Villian your right but Im trying to find the easy way out. The distributor is new, plugs new...sparkwires are MSD 8mm 2 months old...Im running out of possiblities.
To find a miss in the 10 to 16 wires going into the distributor is going to take some time to find, specially since its not always broken, but advice well taken..thanks.
Old Feb 3, 2003 | 06:50 PM
[team iNfiNiT-e]sakot's Avatar
so u got new wires? cause i was gonna say wires could be grounding against something if they arent great, and that could be causeing.......also double and triple check grounds again, no codes?
Old Feb 3, 2003 | 07:13 PM
FitCRX's Avatar
Default Re: Distributor problems ([team iNfiNiT-e]sakot)
Its a possiblity that it could be my grounds...but I think everything in the car would shut off and on.
no codes
1badcrx
May 9, 2009 12:58 AM
88 honda prelude
Jul 28, 2007 05:50 AM
import_king20
Oct 7, 2005 02:01 AM
FitCRX
Feb 2, 2003 11:38 AM
Speedz
Oct 13, 2002 10:19 AM
