distr. rotor screw falls off
Old Aug 14, 2002 | 07:44 PM
LB CRX's Avatar
Default distr. rotor screw falls off
sorry if this isnt hybrid enough, but i just got the car tuned and the screw from my rotor fell off. i put it back in place,tightened it good, and got the car tuned again and it fell off again. whats causing this to happen? does it need replacement? TIA
Old Aug 14, 2002 | 08:18 PM
BreakStuff's Avatar
New User
Default Re: distr. rotor screw falls off (LB CRX)
Make sure the screw is actually tight and snug..
If there is a little bit of play, then try some threadlock..
If there is alot of play try a bigger bolt/screw..
The rotor may spin at speeds of 7500+ rpms , but a high amount of torque isn't needed to hold it into place...
Old Aug 14, 2002 | 09:14 PM
LB CRX's Avatar
Default Re: distr. rotor screw falls off (BreakStuff)
nice name ...i wish i wouldve thought of that
Old Aug 14, 2002 | 10:35 PM
sgT's Avatar
sgT
loctite does wonders.
Of course there are drawbacks, like now i cant get the screw out to change my rotor lol
Old Aug 15, 2002 | 03:50 AM
hondafrk's Avatar
Default Re: distr. rotor screw falls off (sgT)
I had the same fuggin problem a while ago. I noticed that everyonce in a while my car would miss a little when accelerating from a stop. I did a complete tune up a while back and noticed the screw for the rotor fell out WTF!!!! I just used a small amount of locktite. I can still take the screw out also!!
Old Aug 15, 2002 | 07:56 AM
Dutchie's Avatar
Default Re: distr. rotor screw falls off (hondafrk)
Ya defenitely "small amount of loctite".
Unless you want to break the rotor to get the screw out, don't use too much.
[Modified by Dutchie, 11:57 AM 8/15/2002]
Old Aug 15, 2002 | 10:47 AM
Speed PHreak's Avatar
Default Re: distr. rotor screw falls off (Dutchie)
Could be worse, mine fell you going down the road, didn't know WTF went wrong when the car just dies doing 70 mph. 2 hours later after waiting on AAA, I started checking things. When I took off the dizzy the screw fell out.....d'oh
Old Aug 15, 2002 | 10:56 AM
Dutchie's Avatar
Default Re: distr. rotor screw falls off (Speed PHreak)
That stopped your car? I drove around for 2 weeks with the screw sitting inside the cap. Good thing the magnets are in there to stop it from moving.
Old Aug 16, 2002 | 10:58 AM
3rdGteg's Avatar
My screw put a hole in my dist. cap. Somehow it shot out or something and cracked my cap and half of the screw was hanging out-- that's when I knew about mine.
Old Aug 16, 2002 | 12:08 PM
Yeah, the cap screw came out and the rotor spun freely on the shaft it sits on. IE timing was fubar'd.
Old Aug 16, 2002 | 12:21 PM
gsrvx's Avatar
New User
Mine came loose...put a hole through the leak cover and busted the cyp sensor (code 9). Had to replace the distributor housing.
-rod
civic=goodgasmileage
Honda Civic (2001 - 2005)
May 17, 2009 03:55 PM
Sir Kyle
May 10, 2008 06:30 PM
lostkoz
Mar 12, 2006 11:02 AM
blkgsr03
13
Sep 14, 2005 11:15 AM
sickofitall1113
Jun 2, 2005 12:01 PM
