quick help cant get rotor off
im changing my cap and rotor right now and i got the cap off fine and i took that one screw out of the rotor but now it still wont come off. what do i need to do to get it off?
Re: quick help cant get rotor off (sickofitall1113)
try some dwd 40 or something similar
dont wory about breaking something, thats the only screw and the plastic rotor is atached to metal
If all else fails just cut it off
but dont be afraid to tug on it
In all likelyhood some one may have put some rtv on it in attempt to make shure it didnt get loose.
Re: quick help cant get rotor off (Nekekami)
yea i gave it a good hard tug with some gloves on and it flew right off and so did i haha. its off. waste of a thread..sorry.
take a bolt and thread it into the rotor (there should be 4 holes, NOT the holes where the screws go, but one of the other 2. use a hole that does NOT have a tapered opening). thread the bolt in and tighten it until the rotor pops off. you can use one of the bolts that holds the dizzy onto the head. (don't ask).
Re: quick help cant get rotor off (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">take a bolt and thread it into the rotor (there should be 4 holes, NOT the holes where the screws go, but one of the other 2. use a hole that does NOT have a tapered opening). thread the bolt in and tighten it until the rotor pops off. you can use one of the bolts that holds the dizzy onto the head. (don't ask). </TD></TR></TABLE>
yep.. you do that... You have to tighten it as tight as you can, then take it back out, and the rotor will pop off. It may take more than one time though..
I just changed mine(well, not changed, but took them off and got them resurfaced) and I had to do that 3 or so times before the rotor would actually come off.
Draggin99Si
09-05-2003 06:43 PM
