disconnecting rev limiter?
Old Oct 7, 2005 | 08:54 AM
fastasscrx's Avatar
Default disconnecting rev limiter?
Does anyone know if there is any way to disconnect the rev limiter and re-wire it to a on/off switch? If it is helpful, motor is a B16A, not A1 or A2.
Old Oct 7, 2005 | 12:58 PM
PHDZINE's Avatar
Default Re: disconnecting rev limiter? (fastasscrx)
Why would you want to disconnect the rev limiter? It doesn't make you faster going way past your power band. You want to set your rev limiter 500-1000 Rpm's after the point your motor stops making power. What about miss shifts. You know what will happen if you miss a shift at really high RPM's right?
Old Oct 7, 2005 | 02:21 PM
drdisco69's Avatar
It doesn't really work like that (there's no 'rev limiter module') but the effect can be achieved, somewhat, with rom switching. But not having a rev limiter is a disaster waiting to happen, I don't care who you are.
Old Oct 7, 2005 | 11:12 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: disconnecting rev limiter? (drdisco69)
do it do it!!!111eleven!!
https://honda-tech.com/zerothread?id=1277826
Old Oct 8, 2005 | 03:55 AM
fastasscrx's Avatar
I want a rev limiter but on a switch
Old Oct 8, 2005 | 06:16 AM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastasscrx &raquo;</TD></TR><TR><TD CLASS="quote">I want a rev limiter but on a switch</TD></TR></TABLE>
Why?
Old Oct 8, 2005 | 07:49 AM
Padawan's Avatar
Darth ModerVader
Default Re: disconnecting rev limiter? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">
Why?</TD></TR></TABLE>
Haven't you ever just been in the mood to do some engine damage and wished that darn fuel cut wasn't in your way?
Old Oct 8, 2005 | 10:21 AM
Default Re: disconnecting rev limiter? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Haven't you ever just been in the mood to do some engine damage and wished that darn fuel cut wasn't in your way? </TD></TR></TABLE>
The 5th to second downshift will achieve the same result with no modifications.
Glenn
Old Oct 8, 2005 | 02:17 PM
sanimalp's Avatar
$cat /dev/urandom
Glenn</TD></TR></TABLE>
lol
Old Oct 8, 2005 | 08:27 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Haven't you ever just been in the mood to do some engine damage and wished that darn fuel cut wasn't in your way? </TD></TR></TABLE>
I can truthfully answer that question by saying 'yes', with an addition of 'and it wasn't my car'. Lets just say it's easier to swap a motor than to rebuild one with a rod knock.
Old Oct 10, 2005 | 08:11 AM
PHDZINE's Avatar
LOL
Old Oct 10, 2005 | 04:00 PM
doublejz's Avatar
Default Re: disconnecting rev limiter? (PHDZINE)
just get a msd rpm module selector that will let you set it from 7600 to 9800 no need to rev past 10k ofcourse you would need like a 6AL too
KpaTyH
10
Feb 28, 2010 01:52 PM
vi3t00si
Apr 26, 2006 09:32 PM
04Sispeed
Apr 25, 2005 04:10 AM
