Difference in timing belts?
recently bought a fully assembled built block, basically everything brand new...but i dont know what kind of water pump it has on it, so i basically need to know if there is a difference between LS, GSR, B16 timing belts?
B16 timing belts are shorter than 1.8 belts because of the block height.
GSR and LS belts are different in length because the water pumps dont have the same number of teeth. If you have a vtec head i'd recommend a vtec water pump and timing belt.
ITR and GSR timing belts are different from an LS because they have one more tooth on them.
Here are the part numbers...
B16 - 14400-P2T-004
LS - 14400-P7J-004
ITR - 14400-P72-014
GSR - 14400-P72-014
Hope this helps.
B16 - 14400-P2T-004
LS - 14400-P7J-004
ITR - 14400-P72-014
GSR - 14400-P72-014
Hope this helps.
